2004 pt cruiser
Old 12 May 2011, 05:47 pm
Default 2004 pt cruiser
Have a cruiser that the check engine light came on. Took it to the mechanic who put it on the computer and it read can sensor and knock sensor. The car runs perfectly. After resetting the codes, the mechanic(who I trust) said that he doesn't believe there is any problem. The sensor at times goes off by itself, but comes back in always showing cam sensor or knock sensor...sometimes the check engine light goes off by itself...HELP!!!!
Old 12 May 2011, 06:17 pm
Default Re: 2004 pt cruiser
Both sensors can be changed fairly easily if you can't figure out which one it is.
Old 12 May 2011, 06:32 pm
Highly suggest you get OEM sensors, our PT's do NOT like aftermarket sensors!!!!
Old 12 May 2011, 09:30 pm
Thank you for your time....
Old 15 Dec 2011, 03:25 pm
Send a message via Yahoo to echillie1
Hi ,
I'm Esther .. i have a 2004 pt cruiser 5 speed w turbo
i recently replaced the cam shaft sensor because of some serious jerking at approx 30-40 miles per hr, i used a mopar part because it refused an off brand one ...,then my car was getting hot but wouldn'd read that it was so my husband put the new thermostat & did a oil & filter change too ,now today my car is leaking antifreeze & was making a little clinging noise not bad but a little noise ,im thinking this is my water pump now any clues if i'm correct & will my car accept an off brand or does it have to be mopar ??
Old 15 Dec 2011, 04:06 pm
cruserdad1976's Avatar
well the water pump will likely not be mapar and that is ok Im not sure how much you are awared BUT when you do the water pump you will need to do the timing belt ok so maybe not NEED but they are in the exact area and to change one without the other is kind of not smart it is a HUGE labor intense job and can run from $500 to $900 depending one who and where does it the parts are around $200
Old 15 Dec 2011, 04:22 pm
Esther,
How many miles on your PT? Your just taking a wild guess that the water pump is bad, you might not need one. The first thing you need to do is find a garage with a pressure testing kit and see where your leaking anti-freeze is coming from. The "clinging" noise could be just the metal reacting to the hot temperature because you lost the coolant. Let it cool down, add some distilled water to the radiator and get to a garage to find out where the leak is.
Old 15 Dec 2011, 09:05 pm
HI there, my car has 65700 miles on it.
The garage that i took the car to did a diagnostic test I don't know about the compression test,but I will find out.. thanks again! !
2004 pt cruiser dream cruiser series 3 LNBNDN General PT Cruiser Discussions 5 22 Oct 2012 07:55 am
2004 PT CRUISER help demon666 General PT Cruiser Discussions 2 22 Jul 2009 12:24 pm
2004 PT Cruiser GT Eric1987 Tech & Performance Forum 8 14 Oct 2008 07:18 pm
My new to me 2004 PT Cruiser GT rjc757 Turbo Performance 6 19 Jun 2007 02:16 pm
for those with a 2004 n/a Cruiser . . . legion Sound and Security Forum 1 16 Nov 2004 09:37 pm
