How to remove upper motor mount video
Like Tree12Likes
Old 14 May 2011, 04:20 pm
Kawizx9r's Avatar
Default How to remove upper motor mount video
With all the motor mount threads/questions, I thought I'd alleviate the issue by creating a quick how-to video of removing the upper motor mount.
No need to move A/C lines, no need to pull out your headlight or anything crazy. Just watch the video.
For those having trouble with your lower motor mount and require a quick how-to video like the one above, I'll go ahead and create one as well.
Enjoy.
Note: This posting added to the HOW TO thread on the top of the Tech & Performance part of the forum.
Kawi is a friggin genius!
Old 14 May 2011, 04:35 pm
Default Re: Sticky: How to remove upper motor mount video
you may not realize it, but the NAs are laid out with the a/c lines much closer to the top of the timing belt cover than the turbos, like you have. The NAs are the ones that are doing the most of the posting with the replacement questions. It's obviously doable on the NAs, just "harder" than the Turbos.
Jerry
Dino likes this.
Old 14 May 2011, 04:38 pm
Kawizx9r's Avatar
Originally Posted by wwpptc View Post
you may not realize it, but the NAs are laid out with the a/c lines much closer to the top of the timing belt cover than the turbos, like you have. The NAs are the ones that are posting with the replacement questions. It's obviously doable on the NAs, just "harder" than the Turbos.
Jerry
My friend has an '05 N/A and I did it the same way. His lines are a bit closer together just above the motor mount, however I performed the procedure the same way.
Also, I hope people see that my PT is an '03 GT as stated in my sig. I know this works for the N/A, but as for the '06 and above it could be a different story.
Old 14 May 2011, 04:55 pm
Yep, I've done it the same way on every NA I've done and like I (and you) said it it's just a little more involved on the NA as compared to the Turbo. The 06 and up are done the same way as you showed in your video. Good job on the vid, by the way!
I am dailey impressed with the enthusiasm and forethought that you're putting into the direction you're going with your PT. I feel like I've got a turbo by living it through you. Reminds me of the old speed shop days and that's a good thing.
Jerry
Old 14 May 2011, 04:58 pm
Kawizx9r's Avatar
Lol
You've got alot more time and effort put forth into your PT but I'll catch up! Unfortunately, any and all $$$ is going torwards the powertrain. You won't see any exterior pics until another year or so.
Btw, thanks
-Freddy
Old 14 May 2011, 05:43 pm
WolfmanG's Avatar
That's a really good vid, kudos bro.
-Danny Wolfman G
Old 16 May 2011, 08:57 pm
PTCruzing's Avatar
Default Re: How to remove upper motor mount video
Excellent!!!! Thanks for the vid...
Old 16 May 2011, 09:25 pm
Dino's Avatar
Excellent video bro, thanks
Old 17 May 2011, 01:05 pm
thanks - will give it and the lower one a go this evening.
Old 17 May 2011, 01:47 pm
Kawizx9r's Avatar
Thanks for all the props!
If you guys want/need, I can do one of the lower motor mount as well though it's just as easily done. Just requires for you to remove a few more bolts.
Help finding Motor Mount Bracket/Flange? Upper billzilla General PT Cruiser Discussions 1 05 Nov 2011 08:51 pm
Motor Mount CityGirl70 Tech & Performance Forum 11 20 May 2011 10:51 pm
Motor Mount (upper strut) bolts. mdfrodolives Tech & Performance Forum 12 07 May 2011 02:12 am
Upper Motor Mount Issue Mathias Tech & Performance Forum 6 22 Sep 2010 01:24 am
how do i remove the upper grille? VellianPT Exterior Accessories Forum 4 22 Apr 2004 08:59 am
