Piston Misfire
Old 16 May 2011, 05:08 pm
Default Piston Misfire
2007 PT Cruiser - piston 1 misfiring causing slight shake while idling and engine light to come on. Changed plugs, wires and coil, still having same problem. Head gasket changed 1/5/09 and not having any signs that head gasket is bad again; no smoke, oil puddles or hot anti freeze smell. ODB test says piston 1 is misfiring no other codes. Also, put in fuel injection cleaner in tank. Any suggestions? Thank you.
Old 16 May 2011, 05:24 pm
Default Re: Piston Misfire
You need a compression check.
Google Search:
A cylinder may misfire due to loss of compression, which may be caused
by a leaking cylinder head gasket, leaking or sticking
cylinder valves, worn pistons, liners or rings, or a
cracked cylinder head or block If loss of compression
pressure causes an engine to misfire, check the
compression pressure of each cylinder
Piston Conecting Rod loadedchainsaw Tech & Performance Forum 3 02 Mar 2011 07:12 pm
misfire no cel? jacarc1 General Turbo Discussions 4 17 Apr 2010 07:28 am
Misfire pntbalr Tech & Performance Forum 5 05 Dec 2009 09:45 pm
misfire Carl48 Tech & Performance Forum 11 04 Aug 2009 12:09 pm
70 mph misfire? zzzhuh General PT Cruiser Discussions 9 06 Jul 2004 10:09 am
