Help Please.
Old 16 May 2011, 08:02 pm
Default Help Please.
Hi, I went and had my oil changed at Jiffy Lube and the next day my check engine light came on. I did the turn the key 3 times on and off and these codes came up P1684, P0442, and P0455 done. Then I did the hold in the mileage button and turn the key on and these codes came up EL0008, EE08, BL01, 5 of 4.7......Any clue? Thank you for any help. Oh I have a 2002 PT. Cruiser.
I know the P1684 is the battery has been disconnected in the last 50 starts.
I know the P0442 is there is a small leak in the fuel somewhere and may be the locking gas cap I just bought.
But the rest I do not have a clue.
Thank You!
Old 16 May 2011, 08:15 pm
Default Re: Help Please.
Welcome Stacy, if you go to the Performance section there is a sticky showing what the codes stand for.
Old 16 May 2011, 08:21 pm
Awesome Thank you I am new here..... So wasn't sure where to go!
Old 16 May 2011, 08:34 pm
Stacy,
Those other codes are just maintenance codes that don't mean anything that you need. It just means you didn't pull the fault codes correctly. Forget about them and concentrate on the ones that start with a "P".
Old 16 May 2011, 08:53 pm
Thank you CREWZIN.....
Old 16 May 2011, 09:07 pm
From PT Do-It-Yourself.net:
Notes - Some owners have reported experiencing malfunction codes similar to FL 0005, EE 05, and BL 01 during the start of the instrument gauge (Test A) self-test. These are not MIL codes. The readouts simply represent PCM software version information:
FL0002 - Display Application Code Level
EE 02 - Display EEPROM version
bL 01 - Display Boot Loader version
