battery problems
Old 19 May 2011, 10:26 am
Default battery problems
my 04 pt cruiser turbo high output is having battery problems.bought car 2 years ago runs great but 2 months ago i stopped car and tried to start again
nothing i mean nothing no interior lights etc.
replaced battery all ok for 3 months.same problem just now turned car off
and no juice again.very frustrating.can anyone shed some light on the problem.
thanks rapmaster
Old 19 May 2011, 11:09 am
Default Re: battery problems
You didn't fill in your profile or say where your from but hopefully there's an auto store around you like Pep Boys, Autozone etc. that will check your whole charging system for free. Did you do that the last time you put the new battery in?
If the alternator isn't charging the battery as it gets used, you'll completely
discharge the battery. Depending on how much you use the car, it could take awhile before it goes dead.
Old 19 May 2011, 11:24 am
2wdlaser's Avatar
Sounds like an alternator to me.
Old 19 May 2011, 11:58 am
cruserdad1976's Avatar
curzen is right have the charging system checked make sure the conections are clean and tight
Old 24 May 2011, 03:34 am
you know about this.. try it.. this may be very useful ..Batteries must be kept clean and dry. If the top surface of the battery gets dirty or wet, a small flow of electricity will flow between the terminals as the water creates a conductive path. If installed in a location where water can drip onto them, this can cause the batteries to discharge fairly rapidly.
Old 25 Jun 2011, 02:24 pm
Default BATTERY DRAIN PROBLEM
the battery goes flat every second day. did battery amp draw and got 0.13amps from 4 fuses under the hood of the car. 1). IOD 0.02amps. 2) pwr 0.04amps has been fixed. 3) lighting 0.02amps 4) eatx 0.05amps. so are these normal? if not can you please advise on where to look for any fault.
cheers
Old 25 Jun 2011, 06:50 pm
xwing777's Avatar
Take your grounds loose beside battery and clean. Betting you will find loose or corroded wires there. It also wouldnt hurt to add another bigger wire from engine block to battery and another from body of car to battery on the grounds.
These cars have poor wiring and if not kept pristine will cause havoc
Old 28 Jun 2011, 04:28 am
Question Re: battery problems
I have on '02 Cruiser, battery replaced 5/22/11. got off work and it started without any hesitation. Drove 4 miles to gas station. tried to start after fill up and would only click. All other electrical and lights worked fine, just would only give me a click. got a jump and turned over without any hesitation.
Would a faulty alternator cause this issue?
Old 28 Jun 2011, 07:53 am
It might if it's not charging up the battery but you'll never know unless you get your charging system checked. As was said earlier, many places will check the charging system and the battery for free.
Battery Problems??? PTJake Tech & Performance Forum 0 18 May 2007 06:04 pm
Battery cruiser33 General PT Cruiser Discussions 7 16 May 2006 08:28 am
battery twinturbo General Turbo Discussions 7 20 Mar 2004 05:49 pm
Battery Box Hudd General PT Cruiser Discussions 6 24 Nov 2003 10:28 pm
