Rear Wheel Bearing/Hub Assembly Question
Old 19 May 2011, 02:09 pm
Default Rear Wheel Bearing/Hub Assembly Question
Alas, I cannot search! The damn image verification will not load so I'm sorry to ask this ridiculous question.
All I need to know is whether or not a press is required to replace the wheel bearing/hub assembly on the rear of a 2002 PT Cruiser with disc brakes. I'm guessing no but I don't want to tear both sides apart and be stuck. Also, is there really a difference in the hub assembly on a disc brake as opposed to a drum brake aside from the ABS tone ring? Just wondering because I want to order the cheapest part from Rock Auto but it doesn't specify disc or drum in the description.
Interesting story for you guys on this;
So the previous owner decided to torque the rear lug nuts so tight that it's not humanly possible to remove the lug nuts. I literally broke a lug nut in half on a stud (ever see this before!?). So I'm stuck torching one stud out and stripping the rest of the lugs because of how ridiculously tight these things are. So...I'm ready for a lot of mother f'n and probably a bottle of beer by the time these wheels are removed.
Simple tire install gone bad; just my luck! Needless to say the Cruiser is going up for sale once everything is fixed up nicely and cleaned...so long Cruiser.
Thanks guys!
Question after Wheel Bearing Replacement PTdexter Wheels, Tires, Suspension 3 15 Sep 2010 05:05 pm
Which wheel bearing/hub assembly do I need? Bonehead Wheels, Tires, Suspension 5 16 Aug 2010 11:19 am
Rear wheel bearing???? bluewagon Wheels, Tires, Suspension 1 06 Jun 2010 06:43 am
Front Wheel Bearing/Hub Assembly Help UniSaitek Wheels, Tires, Suspension 1 28 Sep 2009 02:34 pm
Wheel bearing/hub Question.. Rowdy Wheels, Tires, Suspension 0 19 Jul 2009 06:06 pm
