Put new fan on
Old 19 May 2011, 04:53 pm
Default Put new fan on
I took the front end apart on my 2005 and installed the new fan ,put it all back togather,AND IT STILL DOES;NT WORK,this car is so frustrateing.tested the old fan with a battery to the neg and pos post and it did not come on,so i guess i should chanage the slow speed relay?I have chanaged the high speed already.
Old 19 May 2011, 05:27 pm
Default Re: Put new fan on
never mind,I am so stupid,i just went out there and climbed under it and noticed the plug to the fan was lose,put it as tight as i could and presto,the fan came on!!!!! the two end dont snap togather like the old one did,so maybe i should tape it tight?
Old 19 May 2011, 05:51 pm
It should snap together, if it doesn't, do something to keep the ends together even it means taping it. There should be a "U" shaped clip on the fan side of the connection that snaps over the locking tab. I guess it broke off when you were taking it apart.
