Front to back rocking motion when easing off brakes.
Old 19 May 2011, 07:42 pm
Default Front to back rocking motion when easing off brakes.
Just bought a used 2001 PT cruiser and it seems ok when driving however it exhibits an unusual front to back rocking motion as I ease off of the brakes like at a stop light? Its sort of like a slight push/pull feeling that you can feel only as you ease off the brakes without letting them go completely. Any car as you ease off the brakes is usually smooth and steady. There are no unusual sounds that I can pinpoint as the cause. This symptom was not that noticeable when I test drove it but I am very eager to understand what could be producing this front to back rocking symptom so that it can be corrected. Please help.
Old 19 May 2011, 07:57 pm
WolfmanG's Avatar
Default Re: Front to back rocking motion when easing off brakes.
when you come to a complete stop, do you bottom out?
-Danny Wolfman G
Old 19 May 2011, 08:04 pm
No, when i come to a stop the brakes don't bottom out.
Old 19 May 2011, 08:08 pm
WolfmanG's Avatar
i meant does the nose of the car dip lower then usual. does it ever scrape the ground when stopping?
-Danny Wolfman G
Old 19 May 2011, 08:15 pm
Sorry, and to answer your question the nose doesn't dip lower than usual or scrapes the ground when stopping. I should also mention that two motor mounts were replaced because it was beleived to be a probable cause however it still did not make a difference.
Old 19 May 2011, 08:23 pm
WolfmanG's Avatar
ok, well, i'm all outta idea's hopefully someone will come along and help you out. Good luck
-Danny Wolfman G
Old 19 May 2011, 08:32 pm
Smile Re: Front to back rocking motion when easing off brakes.
Thanks for your help WolfmanG! Hopefully I'll be able to pinpoint whats causing this.
Old 21 May 2011, 11:19 pm
control arm bushings worn out?
Changing Front Disc Brakes and Front Bumper? HackMATTr General PT Cruiser Discussions 12 14 Feb 2011 12:58 am
Swaying Rocking motion Flyboat Turbo Wheels/Suspension/Handling 5 01 Feb 2011 05:29 pm
PT cruiser only has front brakes? ProDigit General PT Cruiser Discussions 10 29 Jan 2011 03:16 pm
Back Brakes scatgo General PT Cruiser Discussions 5 30 Oct 2010 05:32 pm
Front Brakes HOW TO question for 03 PT barric Wheels, Tires, Suspension 11 15 Jun 2009 03:47 pm
