Clunk under braking to a stop
Old 22 May 2011, 09:59 pm
Default Clunk under braking to a stop
Not an audible clunk, but under constant even braking from any decent (30+) speed to a stop, at ~10mph it almost feels like the transmission is letting lose and grabbing again. Its just a hunch and I'm doing my best to describe it, but the deceleration rate slows for a split second and then catches back up. It happens roughly right around the time the injectors start spraying again for idle is what it feels like, but I've never noticed it so abruptly.
The car is approaching 60k miles and on the "B" service schedule it lists the transmission needs a fluid and filter change. Could this be a symptom of that or should I be looking elsewhere? It almost is certainly a drivetrain problem. I can guarantee its not the brakes and can nearly 100% put it on the transmission which feels like it is slipping or something (its an auto). Anything specific I should check? Is this a known issue?
Old 22 May 2011, 10:01 pm
Default Re: Clunk under braking to a stop
Also, its a 2007 Touring Edition. Not sure if that will specify what motor it is, so its the 2.4L NA
Old 23 May 2011, 07:15 am
I had a 2006 that did the same thing, took it to the dealer and they reflashed the TCM, all was good after that.
Old 23 May 2011, 02:30 pm
Pardon my ignorance, TCM. Transmission Control Module?
Old 23 May 2011, 03:20 pm
Yes!!
Old 23 May 2011, 03:52 pm
Originally Posted by Hooligan View Post
Yes!!
Awesome thanks. Ill change the fluid since it needs it anyway and if it is still having issues ill have the TCM flashed
Old 23 May 2011, 04:08 pm
If it's under braking it's quite doubtful that it's the tranny, sounds more like a warped rotor.
Old 24 May 2011, 09:09 pm
Nah brand new rotors. I know what warped rotors feel like. Its one solid clunk like the transmission is slipping. Not under hard braking, but just gradual even braking to a stop. Its not that deathly crazy vibration or shudder from warped rotors. I used to drive an LS1 Camaro, I know ALLLLLL about warped rotors
clunk clunk durango Tech & Performance Forum 11 01 Aug 2016 10:26 am
New LCA's and still have a clunk... Jetta02awp Wheels, Tires, Suspension 0 24 Jul 2010 07:13 pm
Strange clunk frankb Tech & Performance Forum 4 30 Nov 2009 08:10 pm
Phantom clunk beefco General PT Cruiser Discussions 4 03 Apr 2009 08:00 pm
Slip and a clunk delbassman General Turbo Discussions 15 17 Sep 2007 07:50 am
