rough idle and surging
Old 25 May 2011, 09:21 am
KIMS CRUZER's Avatar
Question rough idle and surging
My 2001 when first started up will have a rough idle. When put in drive will surge or "buck" for a short distant then it will stop doing the surging. It also feels to me the idle is abit faster than before. I'm thinking start with a tune up. I have 118,000 miles and a automatic. Any suggestions before I head out to the shop to prevent getting screwed.
Old 25 May 2011, 10:00 am
cruserdad1976's Avatar
Default Re: rough idle and surging
well you did not say if the timiong belt has been changed so if it has NOT you are over due it is a pain and expensive but it has to be done what you are describing kind of sounds like the cam sensor that is easy and pretty cheap
Old 25 May 2011, 10:44 am
Question Re: rough idle and surging
Hi I am new here, I got a 2004 p/t turbo that is giving several codes P0300,
0201,0202,0203,0204,0582,0032,0038,0452 we have gone in an replaced o2 senors, replaced fuel cap, have cleaned the Iacv, everything points to low voltage on a neg. ground. We reset the lcm by disconnecting the ground it will run great from morning till 6:30 or 7:00 pm in the cool evening it gives us codes an will not run.
Old 25 May 2011, 11:41 am
Given the little bit of info I'm thinking a vac. line came off.
Old 25 May 2011, 12:16 pm
You need to post this in your own thread please. No thread-jacking allowed...lol
Old 25 May 2011, 12:19 pm
So many, many things this could be. Vac line, one of the sensor, belt, plugs, plug wires, fuel filter, air filter, etc. ad nauseum...
Need to know a bit more info. Have you tried the 'key dance' to see if your tossing any codes? If so, post them here. If you have not had your belt replaced, you need to do so and have the water pump replaced at the same time (saves money in the long run). If you have, then look towards a fouled plug, or maybe a bad plug wire. Whens the last time you had the oil changed? Is your car a turbo or NA? If turbo, are you running 93 octane fuel? Whens the last time your tranny was serviced?
Just way too many questions to give you a simple answer.
2001 PT surging and rough when idling Sue Tech & Performance Forum 8 31 May 2016 11:09 pm
Rough Idle-Replacing the IAC Idle Air Controller engineerrock Tech & Performance Forum 9 07 Jun 2014 07:24 pm
Surging at Idle Scarlet2003 Tech & Performance Forum 9 18 May 2011 08:39 pm
Rough Idle, Rough @60, check engine light NEW Dystroy Tech & Performance Forum 8 12 Jan 2009 09:07 pm
Rough idle PTPaul Tech & Performance Forum 1 17 Oct 2001 05:34 pm
