The same old P0340
Old 25 May 2011, 02:19 pm
Default The same old P0340
Does anyone know if something can throw out the P0340 code like a slipped timing belt or something. heres where im at had the ECU tested is good new camshaft sensor new crankshaft sensor i have looked up and down the wireharness i pulled it all the way out from behind the motor to look at but nothing this is the 4th time this car has left me stranded since it hit the 100k miles mark it has 107k always this 340 code does anyone know something i dont
Old 25 May 2011, 02:53 pm
Default Re: The same old P0340
Have you had the timing belt changed yet?
Old 25 May 2011, 03:13 pm
yes but i just rebuilt the head 2500 miles ago. i did all the work. car started first after rebuild the belt was replaced at 97k but that was a long time ago car sat for a yr.
Old 25 May 2011, 08:00 pm
it was the belt
Old 03 Jun 2011, 11:25 am
Hey, JD. I am having the same problem with the 0340 code. I have changed the cam sensor x3 and still get the same code. Is it possible that the torque of 115 in/lbs is so critical that the sensor will not work properly if not torqued to that reading? If so, that may be my problem as I do not have a torque wrench.
Old 03 Jun 2011, 11:39 am
Our PT's do NOT like aftermarket sensors, IF you didn't use OEM's. Harbor Freight Tools have decent torque wrenches for cheap/inexpensive or even E Bay.
Welcome to the forum.
Old 03 Jun 2011, 04:02 pm
Thanks, Hooligan. I will check out harbor Freight for the torque wrench. I did NOT use an OEM sensor. I have been using NAPA's brand. Do u really think that could be the issue here? And thanks for the 'welcome aboard'...
Old 03 Jun 2011, 04:24 pm
I think is the aftermarket sensor, because I didn't even torqued mine
Old 08 Jun 2011, 09:23 am
You guys are awesome. I have been fighting this 0340 code for over a year now. It WAS the aftermatket sensor causing the problem. I installed an OEM sensor and I have not thrown a code since. Thanks....
Old 08 Jun 2011, 09:48 am
Yeah, it's strange - stock ignition wires are crap, but sensors need to be stock...
P0340 & P1391 Rippsnorter Tech & Performance Forum 3 10 Jun 2010 11:37 pm
P0340? j_desan Tech & Performance Forum 10 24 Mar 2010 07:41 am
P0340 Code. BlackJack Tech & Performance Forum 10 01 Mar 2010 09:26 pm
code p0340 sflamedic General PT Cruiser Discussions 5 21 Oct 2008 06:12 am
P0340 Kenny Tech & Performance Forum 19 12 Jul 2005 07:23 am
