Engine cuts out in forward reverses fine HELP!!!!
Old 26 May 2011, 07:05 am
Default Engine cuts out in forward reverses fine HELP!!!!
I have a limited edition 2001 PT Cruiser. IT starts up fine.The motor runs fine while in neutral or idling.Drives perfect in reverse however in any of the forward gears it cuts out after a few yards.Wait a few minutes.Starts fine again & then follows the same as above. No codes are flashing. It is sitting at a mechanic at the moment and they are stumped at what could be the problem.
Any Ideas
Old 26 May 2011, 07:31 am
Default Re: Engine cuts out in forward reverses fine HELP!!!!
Google gives lots of possible answers:
Answers.com - Why would a car run in park but stall in gear
Answers.com - What causes a car to stall when put in gear
Answers.com - Why would a car start but shuts off after it is put in gear
motor pushed forward/rearended someone, help Leannaluv Tech & Performance Forum 3 27 May 2011 09:48 pm
Engine cuts in and out at 2200 RPM tomrinsb Tech & Performance Forum 21 13 Oct 2008 04:50 pm
Engine cuts out when steering wheel turned NH03PtCruiser Tech & Performance Forum 6 13 Aug 2008 08:07 pm
Engine hiccup/lunging forward. What does it mean? yobiebs Turbo Performance 3 15 Jul 2003 05:19 pm
