Center Motor Mount Replacement
Old 28 May 2011, 05:11 pm
Default Center Motor Mount Replacement
I have a 2004 non-turbo PT with around 85,000 miles. The timing belt snapped at 83,000 so that has been done.
I need detailed instructions on how to replace the center motor mount. I've replaced the passenger side motor mounts myself but a mechanic diagnosed that the center mount is bad as well and wants $800 to replace.
I've seen plenty of instructions on how to replace the timing belt but zero detailed instructions on the center mount. My understanding is that the mount doesn't fail often. Thanks!
Old 28 May 2011, 05:53 pm
Default Re: Center Motor Mount Replacement
jj, the last day or so someone else was asking how to do this. Do a search and see if you can find it.
Old 25 Jun 2011, 12:20 pm
i know it's an old post, but you have to remove the engine from the car, OR pull off the timing belt, tensioner and inner timng belt cover. then jack the engine into just the right spot, the mount will come out.
Tags
motor mounts
motor mount cllwyrc Tech & Performance Forum 13 04 Feb 2012 09:02 pm
Motor Mount replacement 2002ptcruiserwoody723 Tech & Performance Forum 20 12 Jun 2011 09:19 pm
06 Motor Mount Replacement Save $$$ GA06PT Tech & Performance Forum 3 11 Oct 2010 03:02 pm
Motor Mount bushing replacement or Dog bone upgrade rspiegel Tech & Performance Forum 4 24 Feb 2010 09:38 am
Motor mount mod. PVO PT Turbo Wheels/Suspension/Handling 4 28 Jun 2003 02:30 am
