A/C Issue -- Help!
Old 29 May 2011, 11:31 pm
Default A/C Issue -- Help!
Evening, all. I just picked up my 2006 PT Cruiser Turbo this past January and am very happy with it so far. Unfortunately, when I bought it, it was cold and snowy, so air conditioning was the last thing on my mind. That being said, when the temps hit 90 and my a/c didn't work, I was not too happy. Anyway, I brought it into a shop near where I live, and the mechanic told me I needed to replace the liquid line assembly with built in expansion valve as well as charge up the system. Total cost: $350
Two days later, I am back to blowing warm air. The a/c did work when I first picked the car up. Since it's a holiday weekend, I need to wait until Tuesday to take it back and fear that I am going to be told a line of nonsense and swindled for more cash.
Any ideas why the system worked intermittently but not anymore? What else could it be, and what should my recourse be with the mechanic?
Old 29 May 2011, 11:44 pm
mityqwik's Avatar
Exclamation Re: A/C Issue -- Help!
welcome to the forum and from virginia,i cant offer any advise,, i have an 06 non turbo and it is doing the same thing,if you get it fixed let us know ,i would love to be prepared when i take mine in next week for repair ,to see if they are going to try and take me for a ride.
It takes 8,460 bolts to assemble an automobile,
and one nut to scatter it all over the road
Old 30 May 2011, 12:39 am
Default Re: A/C Issue -- Help!
I'll definitely keep you posted. I am hoping someone can advise me so I can go back to the mechanic well prepared.
Old 31 May 2011, 10:33 am
I was really hoping someone with some knowledge would weigh in before I went back to the mechanic.
Here's the deal:
The mechanic is now telling me my compressor is bad. He said all the readings were fine on Friday, which really makes no sense to me at all. He said all the freon is still measuring properly as far as pressure goes, but I am looking at another $700 for the compressor and dryer.
He also said that when a compressor is changed, the liquid line and expansion valve is also changed, so the original repairs were necessary.
Someone please advise ASAP so I can at least have piece of mind. Does this sound correct?
Old 31 May 2011, 02:25 pm
cruserdad1976's Avatar
well usally if the compresser goes south it will lovck up or loos all the freon whenm the seals go bad Id say it is verry possable that he is telling you the truth I have no idea what a liquid line is or even where it is sorry
Old 31 May 2011, 03:43 pm
Thanks for responding. What I am not understanding is how the compressor read fine a few days ago but no longer is good. Doesn't make sense to me at all.
Old 02 Jun 2011, 02:22 pm
what is your a/c doing? was it cooling when you drove and did it get hot when you where t a stop and did the car shake. i was having trouble myself with the a/c and it turned out that the fan wasn't coming on when you switched the a/c on. its a very common problem with pt's
Old 02 Jun 2011, 02:43 pm
Hello, my name is John. I have an 06 touring edition. I am having a problem that is affecting the AC on my car. When stopped at a light or sign, the engine will almost sputter to a stop and rev back to idle. I know that the upper O2 sensor needs to be replaced and suspect that is the culprit of the engine issue. The AC starts to blow cold, but will not after the sputter. Could this also be caused by the fan issue?
Electric Blue 2006 PT Cruiser Touring Edition
Old 02 Jun 2011, 03:34 pm
the fan is about 90% of the A/C problems i just replaced my fan and the A/C/ is great it does have a nasty smell some times but i can deal with that
Old 02 Jun 2011, 03:40 pm
did you do it yourself or have a shop do it?
HID issue ilee941 Exterior Accessories Forum 3 12 Mar 2011 09:10 pm
PCM issue polyatt Tech & Performance Forum 2 01 Mar 2011 10:15 am
Key Fob issue Motherlynn Tech & Performance Forum 22 17 Feb 2011 04:41 pm
02 PT issue jparksp Tech & Performance Forum 4 18 Feb 2009 12:11 am
A/C issue. hermtm2 General PT Cruiser Discussions 9 26 Jul 2008 08:40 pm
