Overheating discovery possible quick fix
Old 30 May 2011, 09:30 am
Default Overheating discovery possible quick fix
I had a couple of posts regarding an overheating problem that started after I changed the turbo. Big mystery, as it was fine before the change. I pulled out the thermostat, checked the overflow surge tank, and a whole bunch of other crap. Still not finding the problem, I saw a small nipple (like a wheel cylinder bleed nipple) at the base of the thermostat. If there is a bleeder nipple, there must be a reason! There certainly is, as there was an airlock. Cracked the nipple open and there was a lot of air and hissing, and once the coolant started to come out in a steady flow, I locked the nipple, and it's 100% now.
No one who replied mentioned this as a possibility, so here you go!
If it turns out to be your problem, it's a 2 minute fix.
Just thought I would pass that on.
Old 30 May 2011, 10:02 am
Default Re: Overheating discovery possible quick fix
Sorry for not reading your previous posts....yes somethings you get air trapped in the cooling system making it to overheat.
This is what I usually do when I need to replace the coolant: I fill the radiator, start the car with the radiator cap off and let it warm up until the thermostat open and the coolant starts flowing....then I keep adding coolant until it full ....replace cap and I'm done
Old 30 May 2011, 10:40 am
If all else fails, read the manual.
The Chrysler shop manual and the Haynes book tell one to use that nipple bleeder when draining and refilling the cooling system.
Old 30 May 2011, 10:52 am
Dino's Avatar
Yep it's messy but as always worked for me and seems to get all the air out.
Old 30 May 2011, 11:38 am
A Manual would be a wonderful thing to have handy. Try getting one in Guatemala
Not everyone of the forum members have one, I am sure, so for those who don't, I am just trying to help out with a quick check prior to wasting a lot of time and money, when this may do the job.....
Old 30 May 2011, 12:18 pm
Well FYI .... you can always get the manual online and .....how are we going to know you are in Guatemala if you don't fill out your personal info
Old 30 May 2011, 01:07 pm
xwing777's Avatar
Or you can ue one of these Lisle Funnel #24610 to burp and no mess:
Old 30 May 2011, 01:25 pm
Love it!!!! I want one....my birthday is July 23
Old 30 May 2011, 01:35 pm
mityqwik's Avatar
forget xtrmdc2 birthday--mine's in oct
It takes 8,460 bolts to assemble an automobile,
and one nut to scatter it all over the road
Old 30 May 2011, 01:46 pm
xwing777's Avatar
I will dig mine out and get the exact part number if you want. I know its a little pricey, but it works great and well worth it.
A quick HELLO! AyeCantSeeYou Welcome New PT Cruiser Members 12 08 Jun 2011 03:10 am
New owner needs help QUICK keatoncruiser General PT Cruiser Discussions 2 16 Dec 2009 10:13 am
Just a quick one... Rooney Exterior Accessories Forum 10 31 Mar 2008 11:56 pm
New discovery turbomangt General PT Cruiser Discussions 19 12 Dec 2004 02:39 am
