2006 PT Cruiser, automatic door lock won't work
Old 30 May 2011, 12:29 pm
Default 2006 PT Cruiser, automatic door lock won't work
We have a 06 PT Cruiser and after cleaning the car in the afternoon the automatic door locks are not operable. Along with that when the car is running the gas gauge, temperature indicator and MPH & RPM gauge are not working. Dash lights are not working either. I have read similar issues on this forum, but none addressed the console controls not working. The car runs fine other then that, 80,000 miles. thank you for the help
Old 30 May 2011, 02:36 pm
Default Re: 2006 PT Cruiser, automatic door lock won't work
Did you use a spray cleaner and spray it into places that shouldn't get wet?
Take the negative battery cable off for about 10 minutes. Clean the cable ends and posts while they are off. re-attach everything and see what's working.
Old 30 May 2011, 04:45 pm
No spray was used, we just cleaned the junk out of it and the mats
Old 30 May 2011, 05:22 pm
mityqwik's Avatar
Thumbs up Re: 2006 PT Cruiser, automatic door lock won't work
after you reconnect the neg. cable if it still does not work,check your fuses under the hood behind you air intake and see if you have one burnt out , another option might be your MFS going bad,if that is the case some one here on the forum could give you advice which direction to take for (MFS)
It takes 8,460 bolts to assemble an automobile,
and one nut to scatter it all over the road
PT CRUISER RH & LH FRONT DOOR LATCH LOCK ACTUATOR G56 c13ckb Classifieds: Want To Buy 2 27 Dec 2009 07:28 am
Inside door handle won't work 2006 PT gminfla General PT Cruiser Discussions 6 22 Aug 2009 02:32 pm
Automatic Door Lock Problem iamsmokie Tech & Performance Forum 3 06 Jan 2009 11:02 am
2006 CHRYSLER PT CRUISER AUTOMATIC FACTORY WARRANTY, VERY CLEAN CAR (2006 CHRYSLER PT skylight craigslist 0 15 Jul 2007 01:10 am
Door lock pins, Shift knobs on Automatic encrypta7 Interior Accessories Forum 4 02 Jul 2007 08:48 pm
