Code 'o' rama today
Old 31 May 2011, 04:47 pm
fabreezai's Avatar
Default Code 'o' rama today
Was driving Mater to the store today, running perfect. I parked went to the store (bout 5 min) came back out went to start her and she would not, she would crank but not start. Shut it off, turned her back on and away she went with the CEL on. Got Mater home, asked her for some codes and she said:
P0129- ?
P1681- Driver 5 line 1
P0622- Generator F
P0340- CPS (which I changed with Mopar factory part about a month ago)
P0335- Crank sensor
I reset computer and so far so good. Has anyone else had this same problem?
Thanks in advance!
03' limited, 2.4 NA, 121K
Old 31 May 2011, 05:08 pm
Default Re: Code 'o' rama today
Too many codes. Sounds like the computer had a glitch. You said you cleared the computer. Negative cable off for about 5-10 minutes? Did you try the key dance again to see that everything was gone and did it come up with "done' meaning everything is clear? Hopefully just a one time thing.
P1681 No I/P Cluster CCD/J1850 Messages Received - No CCD/J1850 messages received from the cluster control module.
P0129 (Barometric pressure low)
P0622 Generator Field Not Switching Properly. An open or shorted condition detected in the generator field control circuit
Not going all through your posts, did you have the timing belt and water pump changed?
Old 31 May 2011, 05:27 pm
fabreezai's Avatar
Timing belt was changed. No codes are showing now. bout to take another trip into town, 8 miles, and see how it goes. I'll re post with results.
Thanks for the reply.
Old 31 May 2011, 08:49 pm
fabreezai's Avatar
Took Mater to town,
No problems so far, as crewzin said, might have been a glitch in the system with all the codes at the same time. I'll keep you guys posted.
Cheers!
Old 01 Jun 2011, 04:54 pm
fabreezai's Avatar
Still running great, just for the record. no cel.
What did you do to your NA today? briancpearce General PT Cruiser Discussions 7 03 Oct 2010 08:57 am
USA Today (today) fezzersc General PT Cruiser Discussions 7 09 Jul 2010 10:20 am
Newpaper USA today, talk live at 2:00pm ET today KingKole02 PT Cruiser Convertible Forum 0 27 Feb 2004 03:44 pm
