A/C oil level
Old 06 Jun 2011, 11:01 am
Default A/C oil level
I lost all my freon due to an accident. All is fixed now (radiator, fan, etc.) and I have added 1 can of r134 to my A/C system. I'm concerned about the oil level. When the freon burst out of my system did I lose the oil too? Or does the oil basically sit in the compressor once added? Should I add some oil?
I am getting cool air with just the one can of freon. I do plan to add another can, but wonder if I should get one that has oil built in?
2001 PT Cruiser, Base Model, Dark Blue
NGK GP-Series Platinum Plugs, Autolite Wires
116k, Avg. 22+mpg mixed driving
Old 06 Jun 2011, 12:10 pm
cruserdad1976's Avatar
Default Re: A/C oil level
well first off remember this the right amount of freon is what you need to much is BAD to little is no good either
so If you are getting a can get one witl a guage on it--may be what you alread did
a can with the oil in it is ok some--- of the oil stayed and some was lost --again to much oil is bad not enought is not good either the seals drying up is the main cause of AC problems
Id add a can of freon with the ester oil in it but id for sure use a can with a guage on it and do not go into the red area
Old 04 Feb 2014, 07:46 pm
PT101's Avatar
On PT's it will be 25.oz of freon type 134a and on Compressor Oil 5.25.oz type PEG150
Old 05 Feb 2014, 01:06 am
I didn't read where you vacuumed the system down.
R134A needs to be filled by weight and that's hard to do with cans.
A violent discharge likely removed quite a bit of oil. It is dispersed throughout the system and most was probably in the condenser and evaporator.
You might call some shops and get their recommendation.
______________________________________________
Most misunderstandings in the world could be avoided if people would simply take the time to ask, "What else could this mean?
2001 PT Cruiser LE 5 spd, original owner, no mods, MOOG arms with spherical bushing (ride is now a bit harsher vs OEM)
- 109K replaced timing belt/WP/tensioner/idler/crank&cam seals with same 1st gen design. That was a fun day and half!
- 119K Gates water pump failed after only 10K miles. Replaced with Airtex. This time around it was a 7 hour job.
2001 PT Cruiser LE AT 59K miles. Bought used, newest addition to the family
how to level suspension bhunt41 Wheels, Tires, Suspension 4 28 Feb 2011 08:13 am
Not level in back? cnjvh General PT Cruiser Discussions 7 21 Apr 2010 12:31 pm
PH level of HOAT Coolant yaschief Tech & Performance Forum 2 13 Aug 2008 01:01 pm
Gas level/gaugage LoboMXGT Interior Accessories Forum 3 28 Sep 2004 09:52 pm
Coolant Fluid Level Ed Lim Tech & Performance Forum 2 28 Sep 2003 07:38 pm
