Codes p0031 & 0037, intermittent power loss, anyone familiar with it?
Old 07 Jun 2011, 01:04 am
Default Codes p0031 & 0037, intermittent power loss, anyone familiar with it?
Hi--it's an '05 turbo automatic, the engine light stays on steadily but only some of the time (couple days or hours on, a couple off, though more & more frequently), and usually there's no effect on the performance, but also more & more frequently there is an occasional effect: no tranny response to the pedal, stays in 1st. So I have to rev it pretty hard & that's not an instant response either--but when I do, after a few seconds it will snap back into running as usual (though the engine light stays on). Anyway, the codes mean: Heater Circuit Low Voltage Bank 1 Sensor (1 & 2). Can such a thing account for this? Does anyone know the fix? If so . . . infinite gratitude is yours!
Old 07 Jun 2011, 09:00 am
Default Re: Codes p0031 & 0037, intermittent power loss, anyone familiar with it?
It sounds as though something in your electrical system is failing, be it your battery, alternator, or the wiring. Most every component in the car is controlled electrically and a bad alternator, battery, ground, etc. can cause the issues you are experiencing. Any auto parts store will test the electrical system for you, or you can use a multimeter to test it yourself.
Old 08 Jun 2011, 12:35 am
Thanks for the tip, Paul-- I know the battery is on the weak side, I'll have it all checked out asap, it'll be great if it's such a simple fix . . . Mark
Tags
intermittent power loss, p0031, p0037
Codes p0031 & 0037, intermittent power loss, anyone familiar with it? Memark General Turbo Discussions 3 04 Jun 2011 12:47 pm
intermittent power loss oldguy829 Tech & Performance Forum 19 07 Feb 2011 04:53 pm
