Power Steering Leak (help)
Old 13 Jun 2011, 04:32 am
mjb457's Avatar
Default Power Steering Leak (help)
There are many posts on here PS leaks..mine is under the car on the passenger side--seems to make the boot area wet..not much (since PS reservoir stays full..any tips or help..(seems like every month something else )Im at 91K) time to trade? (again thanks) MJB
Old 13 Jun 2011, 04:43 am
swanjack's Avatar
Default Re: Power Steering Leak (help)
If you raise the car and turn the steering from full lock to full lock, you should see where it's leaking from (the fluid will squirt out for a second, probably just before full lock). Mine was leaking due to a hole in the rubber tubing. You can DIY if your handy with spanners. Getting the screw off at the pump is the hardest part as access to it is a nightmare.
Old 13 Jun 2011, 04:52 am
mjb457's Avatar
Ok,,are you saying its a hose change or pump?/ What would happen if you keep an eye on it and drive & just make sure PS is always full? Any harm? again thanks MJB
Old 13 Jun 2011, 05:46 am
swanjack's Avatar
It could be either. If the hose is leaking you'll see a squirt of fuild coming from it when its under pressure, biggest pressure being on full lock. If the pump is leaking it wont be as dramatic, just a steady leak down onto the drive belts. If it's the pump you may get away with putting something like this into the pas fluid
Lucas Power Steering Stop Leak stops leaks and noise quickly.
it swells old seals and closes the leak.
If there is a hole in the hose that connects the pump to the rack, then a new hose is needed, not an expensive part ($25??? on rockauto IIRC), maybe a few hours to replace if you've not done it before.
If you drive it without getting it fixed, there's the chance of dripping fluid catching fire on the exhaust.
Power steering leak oliverav Tech & Performance Forum 12 07 Apr 2013 09:46 pm
Power steering high pressure hose leak. canbug Tech & Performance Forum 2 13 Mar 2011 08:16 pm
no power steering rsr02 General PT Cruiser Discussions 1 29 Nov 2009 12:36 am
ATF + 4 or 5 for power steering? quicksilverdon General PT Cruiser Discussions 2 21 Feb 2005 05:00 pm
Power steering leak . . . gonzowing Tech & Performance Forum 5 15 Apr 2004 10:28 pm
