Emissions or Transmission Problem
Old 15 Jun 2011, 09:31 pm
Default Emissions or Transmission Problem
Hi, my name is Kenny. I have a 2002 Cruiser N/A Touring with about 130,000 miles on it. The other day I went outside to go to the gas station, which is about a 5 mile round trip, started the cruiser and put on my seat belt. She hit about 2000 on rpm and then went back down to normal. I backed out and continued down the driveway. The motor acted like it was surging or pulling me without putting my foot on the gas, taking me down the driveway faster than normal until I hit the brakes and then it quit. All was well until on my way back from the store I started to slow down from 55 mph to make a left hand turn and as I hit about 40-35mph the rpm kept bouncing from 2000 to 1000 back to 2000 until I came to a complete stop and then drove fine after that. I know I should've tried to put it in neutral and see if it continued, but I didn't and it hasn't done it again in the past couple of days. What would you think the problem is? I have checked the IAC, it looks very good, no build up or anything like that anyway. Could it be the EGR or the Transmission Solenoid. I appreciate any suggestions you might have. Thanks to all. I'm fixin to leave work will get back on when I get home.
Old 15 Jun 2011, 10:34 pm
Default Re: Emissions or Transmission Problem
Oh and I forgot to mention that I checked for codes using the key trick and an obd II scanner and there is nothing pending. Don't know if this helps but the a/c was on and temps outside were hitting 85 to 95 F.
Old 16 Jun 2011, 10:26 am
cruserdad1976's Avatar
no9t real sure but the big question is have you donme yopur timing belt cause if not you are way past itme
Old 16 Jun 2011, 11:15 am
Yes timing belt was done around 90000 miles.
Old 16 Jun 2011, 12:45 pm
Ok so I just went to the store and the cruiser started to do the rpm bounce again so I shifted it to neutral and the rpm hit about 2500 and stayed there for a minute before coming back down to normal. The trans is an auto 4 speed which is using atf+4.
Transmission Problem Hooligan Tech & Performance Forum 0 09 Jul 2009 09:21 am
Transmission problem perhaps? banddork123 General PT Cruiser Discussions 2 09 Oct 2008 09:05 pm
Transmission problem Syl General PT Cruiser Discussions 4 20 Sep 2008 09:50 pm
Transmission problem turbotime Tech & Performance Forum 3 13 Nov 2005 06:28 pm
transmission problem dbraveman General Turbo Discussions 12 09 Mar 2004 11:44 pm
