2002 PT Cruiser Sunroof wont open!!
Old 16 Jun 2011, 01:57 pm
Default 2002 PT Cruiser Sunroof wont open!!
I bought a my pt cruiser a yr. ago and I have 3 buttons for the sunroof. 1. vents 2.closes 3.?? I would assume that one should open it completely but mine will not. I heard something about fuse #14 its not blown and it says on my guide that its my radio fuse anyways. IDK I really want to figure this out myself so if anyone has any suggestions for me please let me know!!! Thanks for your help!!
Old 16 Jun 2011, 02:07 pm
Default Re: 2002 PT Cruiser Sunroof wont open!!
Unless they changed it between my 01 and your 02 (I don't think so) the No#14 fuse (20A) in the interior fuse box is for the Overhead Console and the SUNROOF.
Old 17 Jun 2011, 12:01 pm
IDK. but mine says radio and none of the other fuses say anything about sunroof or overhead console.
Old 17 Jun 2011, 01:06 pm
Strange. My No#13 10A says Radio.
The guide you referred to, is that the inside of the fuse door, and your saying none of the fuses say: O-H CNSL with SUNROOF under that ?
Old 17 Jun 2011, 02:32 pm
Yeah the guide on the fuse panel. This is what #14 says O-H CNSL RADIO
Old 17 Jun 2011, 03:31 pm
OK, hard to believe they would change that. How about #13, what does that say?
Old 17 Jun 2011, 03:41 pm
Here is a list:
1. HD-LAMP SWITCH
2. PARK LAMPS
3. RKE OR LKS
4. DRV HTO SEAT
5. AIRBAG RUN ONLY
6. B/U EBL NEU SAF
7. HVAC BLOWER
8. FOG LMP NON BUX
9. AIRBAG RUN-ST
10. CLUSTER RKE SKIM
11. ENG MOD ABS-TRAC
12. POC RLYS LDP
13. INT LIGHTING
14. O-H CNSL RADIO
15. WIPERS COMB FLS
16. A/STOCK IGNITION (which there is not a fuse there)
17.PASS HTD SEAT
18. HEATED MIRRORS
19. RT HD-LAMP
20. LT HD-LAMP
THATS ALL OF THEM
Old 17 Jun 2011, 04:01 pm
Thanks. Hard to believe they changed it between 01 and 02. I guess if your radio is working, the sunroof should too. Sorry, don't know what else to say. Hopefully someone will see this thread and have an idea what to check.
Old 17 Jun 2011, 05:36 pm
i have an '02 w/moonroof as well. when i first took it for a test drive, the moonroof wouldn't slide open. figured it had something to do with it being winter here. when i bought it, it worked, but sporadically. still works but i have to play with it a little.
i'm gonna go out on a limb and say it's the control button. if you can get the console off, you can try jumping the wires that go to that particular button.
if it works, then you know for sure it's the switch.
hope this helps and good luck with it.
Old 18 Jun 2011, 08:44 pm
BladeRunner's Avatar
My '01 is working OK,but, I've wondered if there are lube points I should be taking care of? Anyone know?
2002 PT wont start TampabayCruiser Tech & Performance Forum 6 10 May 2011 05:41 am
02 cruiser wont run after rain chilis420 Tech & Performance Forum 7 10 Apr 2011 07:08 pm
2002 PT Crusier showing 4 codes and wont start mattbuddah81 Tech & Performance Forum 6 01 Jun 2010 08:41 am
Doors wont open! HELP yteka99 General PT Cruiser Discussions 4 30 Dec 2009 04:46 pm
'03 Cruiser Sunroof vibrations indianboy107 General PT Cruiser Discussions 3 28 Mar 2007 01:15 pm
