Noob with A/C problem
Old 17 Jun 2011, 12:24 am
Default Noob with A/C problem
New here with a question regarding the A/C system.
PT Cruiser with just over 100,000 miles had a weird smell (not trans fluid, not engine oil, and not engine coolant) followed by the A/C blowing warm. Compressor is clicking on and radiator fan is kicking on when A/C button is engaged. Checked the LOW A/C port with a gauge and its showing almost no pressure. My questions are basically, Why is the compressor still working? Which lines are more prone to leaks?
Thanks in advance for any advice. I am dying here in the desert of New Mexico in a black PT with no A/C. I will try to add some refrigerant but I know it will just leak out.
Thanks,
Tino
Old 17 Jun 2011, 05:17 am
OrlandoSB's Avatar
Send a message via AIM to OrlandoSB Send a message via Yahoo to OrlandoSB Send a message via Skype™ to OrlandoSB
Default Re: Noob with A/C problem
My AC was blowing cool, not cold. Compressor was kicking on and off too. Took it to a Meineke shop just to get some quick advice, they wanted 100 bucks just to boost charge it. Same with Pep Boys, 78 bucks. Went to Walmart and got a can of EZ Chill for 25 bucks and now blows cold and holding the charge after 3 weeks. I would suggest taking it to a shop and have them charge it and they can put a dye in there and see where its leaking from.
Hotter than a EZ Bake Oven in hell, here in Orlando too, we need our A/C!!
Old 23 Jun 2011, 03:52 am
I did find the culprit hose. Apparently it got damaged from bottoming out the front end on a high driveway. It is the line with the high pressure service port. Had a problem getting it out though. Just snipped the rubber line in half and pulled it out. Took it to a place to have barbs welded on making future replacement of the rubber hose a snap.
Tags
a/c, air conditioning, leaks, refrigerant
Noob hello scrw General PT Cruiser Discussions 3 29 Nov 2009 12:02 am
Noob Thanks EDGEFIND General PT Cruiser Discussions 3 26 Nov 2009 02:44 pm
Noob with a serious oil leak, Help... TSPalmer Tech & Performance Forum 7 13 Dec 2008 01:08 pm
Help a Noob!! warped General PT Cruiser Discussions 5 20 Oct 2007 12:27 pm
serious noob question caraloco Stage Turbo Kits 13 02 Aug 2007 04:31 pm
