Still need HELP...!!!
Old 19 Jun 2011, 06:38 pm
Default Still need HELP...!!!
ok guys, so i posted the other day about my fan problem. i go that all worked out. (With some help from this forum of coarse) but the reason i changed my fan motor was because of overheating issues. so my fan is now properly working.. PT is still overheating. so this is the list of things I've done to try an fix it.::
1.new water pump
2.new timing belt
3.new thermostat
4.new thermostat housing
5.new temperature sensor
6.new high speed fan relay
7.new low speed fan relay
8.new main A/C relay
9.new EGR valve
10. new 16psi radiator cap
11.new fan motor
12.radiator flush
13.bled the coolant system
Other then change the radiator or the head i dont know what else to do... any suggestions or cheap ideas would be very helpful... thank you to anyone who responds...! it's a 01 limited 2.4 non-turbo 5-speed
Old 19 Jun 2011, 06:48 pm
Default Re: Still need HELP...!!!
As far as driving it, it dont get hot well driving unless for a long period of time, or if I'm pushing it hard then it gets hot. and no matter how long i run it it always makes a bubbling sound from it boiling over into the overflow tank. it always makes this sound. an i do not know how to make it stop...
also whats the recommended antifreeze for my '01? anybody???
dex-cool is what they filled it up with at the shop...
Old 19 Jun 2011, 07:03 pm
You have to use OEM or Zerex G-05 coolant with 50% distilled water. Do not any other stuff.
Old 19 Jun 2011, 07:22 pm
i have no idea where to began looking for that at. could that be the reason its still overheating?
Old 19 Jun 2011, 07:26 pm
SCBluePT's Avatar
You can get it from the dealer.
Old 19 Jun 2011, 07:34 pm
whats the price from the dealer?
Old 19 Jun 2011, 07:45 pm
Dill's Avatar
I got zerex from napa, 15 bucks a gal non diluted. Took one bottle and one gal of distilled water
Old 19 Jun 2011, 07:59 pm
You can also get it at Carquest or Grainger .
Old 19 Jun 2011, 08:04 pm
Dex-Kool WILL ruin your radiator!!!
Old 19 Jun 2011, 08:12 pm
so should i just go ahead an get a new radiator well im doin all this workand fill it up with G-05?
