A/C problem
Old 21 Jun 2011, 11:45 am
Default A/C problem
I have an 03 PT 2.4, 75K. A/c is putting out 48 degree air, but the high pressure safety switch is blowing off. What would make such high pressure in the system? sounds like the switch is doing its job.
Old 21 Jun 2011, 11:52 am
Default Re: A/C problem
The main cause is because the A/C system is getting hot. Could be because the radiator fan is not working properly to cool off the condenser and the compressor itself. Eventually you blow off enough pressure that you'll need to fill up the system but it will start to blow warm air first and the pressure sensor will recognize your low in R134a and stop the compressor from coming on.
Old 21 Jun 2011, 12:32 pm
Engine fan should come on when A/C is on - on highway, does it still cut out?
Also possiboe thw high pressure switch is defective and you don't have high pressure.
If engine fan comes on, take it to an A/C place.
Old 22 Jun 2011, 10:56 am
I turned on the A/C while car was running and the fan did not come on. The temp gauge does not show overheating, but we only drive car a few miles at a time, maybe 5 at the most. It is my wife's and she not not go anywhere.
Old 22 Jun 2011, 01:22 pm
I am new to this and think I may have done something wrong on replying to Quicksilverdon.
the cooling fan did not come on when I turn on the A/C. We do very little highway driving and haven't notices a temp increase.
Old 22 Jun 2011, 07:59 pm
mdfrodolives's Avatar
mkinsey, when my fan went out, the temperature gauge never went above the "almost-halfway-mark". Go figure! However, the A/C blew warm at idle and the engine stuttered. Does yours?
Even if it doesn't, drive the car till the engine gets good and hot, then--at idle--check to see if your fan is coming on at high speed (it'll make a somewhat loud whirring sound at high speed). If not, it's probably the fan.
There is also a "sticky" on how to check the fan on this forum, I believe.
Tim
Old 22 Jun 2011, 08:12 pm
digitalpinscruiser's Avatar
Send a message via AIM to digitalpinscruiser Send a message via Yahoo to digitalpinscruiser
Hey mkinsey7 I just had this problem but I was getting cold air...my fan would not come on at all. Cruiser never over heated but started running just a bit over the half way mark and also started stuttering or surging when idle or at a light. So I recently changed the fan this past weekend and all those bad symptoms went away.
New fan is working now, no more surging or stuttering when idle and also engine temp either stays just under or at half way mark.
2007 PT Cruiser Touring Edition
Old 23 Jun 2011, 10:47 am
Talking Re: A/C problem
"go Figure" I went out this morning, drove PT till hot, pulled into garage, fan is running, turned on AC first notch and air was 50 degrees in just minutes, turned ac off, watched the fan and it finally quit spinning, tuned ac back on and the fan started right up. I let sit running for 10 minutes with ac on and no blow off and engine is running smooth and all seems well. I know computers get viruses, but my car? Thx to all for help, will just have to keep an eye on it for now.
Old 25 Jun 2011, 02:34 am
Mkinsey, my fan would work sometimes and not work at other times, too. Sometimes it just ran too slowly. At any rate, the fan needed replacement. Remember the movie "The Money Pit"? In one scene, Tom Hanks asks one of the Shirk brothers how he could give an estimate on his house's plumbing when he hadn't even looked at it, yet. The brother replied, "I looked at it three years ago ... and it probably hasn't gotten any better."
Our fans are kind of like that. They just don't seem to improve with age.
Tim
Yet another problem garner49 Tech & Performance Forum 4 26 Mar 2011 03:14 pm
is it a balljoint problem or a wheel bearing problem? phtech Tech & Performance Forum 2 05 Mar 2011 04:33 pm
any one else have this problem tommeyb General PT Cruiser Discussions 13 07 Apr 2008 12:21 am
RDS problem Brad Vandrasik Sound and Security Forum 3 02 Jan 2004 01:15 pm
