01' PT stumbles, barely runs
Old 22 Jun 2011, 08:13 pm
Default 01' PT stumbles, barely runs
I got in my car today and it won't stay running not enough it seems to throw a code. I have to hold the throttle wide open just to keep it stumbling along, like its down a cylinder or 3. It has shown me signs of major malfunction before this.
I got p0601 and p1684 off of the key dance. Is it really a pcm or something else? I was thinking an o2 sensor, any ideas would be greatly appreciated.
Thanks
Old 23 Jun 2011, 03:12 am
chigger_ns's Avatar
Default Re: 01' PT stumbles, barely runs
P0601-INTERNAL MEMORY CHECKSUM INVALID
You need a new pcm. If you buy a used one, you need to get it re programed. Some venders will program it for you if you give them your vin and mileage.
2001 PT 5 speed Touring Edition
Eibach Pro Springs, Energy Suspension HyperFlex Master Kit bushings, 17" RTX Euro wheels, K&N drop in air filter, MotoMaster flat plate AGM battery, KYB GR2 shocks and struts, Booger standard shifter bushings, Ooogah horn.
Old 23 Jun 2011, 06:14 am
02 sensors really don't start working until the car is warmed up and it doesn't sound like you can even get to that point. Take the negative battery cable off for about 5 minutes. That resets the computer and clears the code. Replace the cable, drive it and see how it runs. If it goes back to the old way and the fault light comes on, check to see if the bad check sum comes up again, follow chigger_ns's advice.
Top speed barely 100, WHY?? snakepitt1 Tech & Performance Forum 47 17 Aug 2016 06:02 pm
Fan Runs But No Air Comes Out tomgrigsby General PT Cruiser Discussions 4 20 Apr 2011 03:53 pm
Brakes barely work...Im stumped strokedmaro General PT Cruiser Discussions 2 11 Jan 2011 02:07 pm
02 PT Cruiser barely hitting 95 MPH LStheProducer Tech & Performance Forum 11 26 Dec 2007 07:02 pm
Says runs Hot stirfry General PT Cruiser Discussions 8 01 Apr 2004 11:25 am
