2004 PT Cruiser, high pitch whine
Old 23 Jun 2011, 02:53 pm
Default 2004 PT Cruiser, high pitch whine
I have a 2004 PT Cruiser, non turbo, has 111,000 or so. I recently noticed a high pitched whine when I accellerate. It does continue whether I turn or go straight. It is harder to hear it when I am at highway speeds. Does not make the sound when at a stop and idle. I keep up with the maintenance of the vehicle. Also noticed a clicking sound for the first couple seconds when I start the car but goes away and feels like its in front and low from the drivers position. Finally when car sits overnight, I start the car and the oil light stays on, I turn off the car and restart it goes off. It does not come on at all when driving, only when starting occasionally. Check the oil regularly and not losing any. Mechanic does not think its the oil pump. Any ideas!!!
Old 23 Jun 2011, 03:10 pm
Default Re: 2004 PT Cruiser, high pitch whine
Did you do your timing belt, water pump, idler pulley and tensioner yet? Maybe is coming from there
Or if is automatic, it may be going bad?
Old 23 Jun 2011, 03:41 pm
The oil pressure sensor on the back of the engine has been know by many members to give an indication of trouble by turning on the engine light. Some have even had trouble starting the car with the oil light being lit.
Old 23 Jun 2011, 08:24 pm
have changed the timing belt and water pump about 35,000 ago. have not checked the other two, and yes it is an automatic.
As far as the engine light, that has not come on at all, just the oil light when i start it up.
thanks
Old 24 Jun 2011, 09:03 am
I paid more attention to the whine that was going on with my cruiser. I did notice that the whine is more prominent after I have driven the car for a while versus when I start the car. Dont appear to be losing power and does not appear to be sticking when shifting gears (automatic).
Old 06 Nov 2011, 03:35 pm
Hi rhunt110
I've got the exact same high pitched whine with my '04 Turbo PT Cruiser (mine has about 170k miles). Did you ever get it diagnosed?
High pitched whine from radio RacerX Tech & Performance Forum 3 14 May 2011 08:51 am
High pitch squeel from under hood when warm misterwhisker Tech & Performance Forum 13 27 Oct 2010 06:04 pm
2004 2.4 turbo High Output dvboth General Turbo Discussions 14 24 Apr 2008 03:39 pm
high pitched whine triggerman Sound and Security Forum 7 12 Sep 2006 04:37 pm
Strange Low-pitch Whine jramosGT General Turbo Discussions 12 26 Sep 2003 09:14 pm
