manually turning the crankshaft
Old 24 Jun 2011, 12:36 pm
dgb dgb is offline
Default manually turning the crankshaft
hi again... so I got my head back from the machine shop and am putting the timing belt back on.. but how do you guys turn the crank shaft... I was able to do it by hand to get to tdc, but I'm not gonna be able to do two full revolutions like that... do I really need some special tool???
thanks
Old 24 Jun 2011, 05:55 pm
Default Re: manually turning the crankshaft
Hello, Haynes manual, says you can use a breaker bar with a socket. also remove all spark plugs it will make it easier to rotate the engine by hand.
Old 24 Jun 2011, 07:57 pm
rcktpwrd's Avatar
A 19mm socket on the balancer bolt and a 1/2" ratchet wrench or breaker bar. Be sure to turn clockwise...
Joel
www.rcktpwrd.com
Where is the crankshaft sensor? barry8108 Tech & Performance Forum 2 08 Dec 2010 06:24 pm
Crankshaft BACdaG1 Feedback and Support 0 09 Nov 2010 09:36 pm
HELP! Crankshaft pos sensor won't come out! reluctantlycrouched Tech & Performance Forum 0 09 Jul 2010 08:33 pm
Crankshaft damper won't come off!! able2able Tech & Performance Forum 7 03 Jun 2010 09:48 pm
crankshaft pulley removel fugittj Tech & Performance Forum 4 29 May 2005 12:36 pm
