serpentine belt tensioner
  • 1 Post By CREWZIN
Old 26 Jun 2011, 12:22 pm
Default serpentine belt tensioner
hidy ho, im finally getting my wifes rig put back together from the timing belt job. when i removed the ac pwr steering belt it was simple to release the tensioner to remove belt. however, upon assembly the drive belt is way too loose. the only part thats moved was the ps pump and it went back into same mounting spot so no adjustment there. tensioner still functions but just does tension suffiently. there are some gage marks on it. can the old be adjusted or has the belt stretched too much to reuse? thx,
Old 26 Jun 2011, 01:23 pm
Default Re: serpentine belt tensioner
Hopefully someone with more experience with the serpentine belt will come along and help you. It seems to me that belt wouldn't stretch that much so the tensioner wouldn't take up the slack, especially since it fit tight when you took it off. (It did fit tight before, right?) To release the tension on the tensioner to take the belt off, you just turned the center nut clockwise, right. Not sure why it wouldn't take up the tension now.
Old 27 Jun 2011, 01:04 am
mdfrodolives's Avatar
Hm, since you turned the tensioner bolt clockwise to loosen, maybe (after putting the belt back on), you could try turning the bolt counter clockwise ... slowly till it stops.
But my guess is, the serpentine belt adjuster is shot--or your belt is too worn. Because I've heard that when putting the belt back on, you also have to turn the bolt clockwise--just to get the belt on--then the tensioner will do the tightening when you turn the bolt counterwise till it stops and then release the bolt.
The Hayne's manual shows which mark indicates a worn belt. It's the mark that is to the right of the middle mark. If this "far-right" mark lines up to the Belt-length indicator mark, which is located behind the tensioner, then the belt's worn for sure.
Tim
Old 27 Jun 2011, 10:13 am
RaineMan's Avatar
If you are changing the timing belt you might as well change the serpentine belt(s) as well. They're cheap and it'll save you time down the road.
Serpentine belt change yteka99 Tech & Performance Forum 18 11 May 2017 02:41 pm
Serpentine Belt Question. Tonys18t Tech & Performance Forum 9 12 Sep 2014 12:14 am
PT Cruiser 2.2CRD 2003 (european Model) serpentine Belt Tensioner dustcloud Tech & Performance Forum 2 04 Mar 2011 06:16 am
HELP REPLACING SERPENTINE BELT TENSIONER pt_crewser Tech & Performance Forum 6 26 Nov 2010 07:59 am
New serpentine belt already? RJ General PT Cruiser Discussions 4 07 Sep 2004 08:12 am
