installed new water pump/timing belt.. now it backfires.. please help
Old 26 Jun 2011, 02:07 pm
Default installed new water pump/timing belt.. now it backfires.. please help
Hi everyone, I just recently purchased a 2001 Cruiser Limited Edition. The water pump went out on it the second day I had it, so I went to Auto Zone and grabbed a new one and a timing belt, as well as a altinator belt and serpintine while I was at it. I instaleed everything and now when I turn the car on, it back fires when I rev the engine just a little. I set up the timing markings perfect. I triple checked once the where on just to see if it was off. They still lined up. What is causing it to back fire then? Any advise will be greatly appreciated
Old 26 Jun 2011, 02:34 pm
Default Re: installed new water pump/timing belt.. now it backfires.. please help
I think your 180 degrees off. Not a mechanic but I've read where the back-firing occurs when timing is off. Hopefully someone with more experience with timing comes along and helps out.
Old 26 Jun 2011, 02:43 pm
I wonder if I can work on the timing without unmounting the engine again, that would be awesome. Thanks for the quick reply Crewzin
Where to buy Timing belt/tensioner/water pump KalSaint Tech & Performance Forum 4 24 Nov 2011 09:02 am
water pump and timing belt bryanschacht Tech & Performance Forum 3 15 Apr 2011 05:32 pm
TIMING BELT AND WATER PUMP CHANGE?? mjb457 Tech & Performance Forum 20 03 Apr 2011 10:38 pm
Changing timing belt and water pump.... missingwhatsnear Tech & Performance Forum 14 13 Dec 2010 04:22 pm
How much is timing belt/water pump installed by mechanic? BrianW General PT Cruiser Discussions 13 03 Nov 2010 09:19 pm
