PT Cruiser Forum (http://www.ptcruiserlinks.com/forum/)
-   Tech & Performance Forum (http://www.ptcruiserlinks.com/forum/tech-performance-forum/)
-   -   Help - Timing Chain??? (http://www.ptcruiserlinks.com/forum/tech-performance-forum/36961-help-timing-chain.html)
Louisa 27 Jun 2011 08:51 am
Help - I have a PT Cruiser 2.2CRD (2005) and have done approx 100K to date - someone has mentioned that I should have had the 'timing chain' replaced, yet although I have had PT fully serviced over the years I cannot find any reference to this. When would it be recommended to be changed? Is it a mileage thing? I don't really know what it does or what will happen if it breaks - can someone help to explain??? Thanks Louisa
Kawizx9r 27 Jun 2011 10:16 am
Re: Help - Timing Chain???
Hello Louisa and welcome to the forum!
By the looks of things, you're outside the US am I right?
As for your timing chain, I think you haven't found anything because what PT Cruisers have is a timing belt. They can snap over time and are recommended for replacement (along with waterpump, tensioner, etc.) at about 105k miles. Alot of people do it before they reach 105k though, and a few unfortunate people have had theirs snap on them so they're forced to replace it anyway.
It does require a bit of labor, and roughly clocks in at 6-7hours to do (at least for the 2.4ltr version here).
Hope I helped and best of luck to ya!
-Freddy
cruserdad1976 27 Jun 2011 11:04 am
well OURS has a belt his is a desiel and I think has a chain
Kawizx9r 27 Jun 2011 12:04 pm
If it's a chain then I doubt the OP would have anything to worry about then.
Chains are supposed to last the life of the car, though some people do change them out at about +250k miles.
cruserdad1976 27 Jun 2011 01:30 pm
I think the 2.2 CRD is a turbo desiel but you knwo i COULD BE WRONG
