Need help
Old 30 Jun 2011, 03:21 am
Default Need help
So I'm a noob to this forum and am reaching out for any help I can get. I am working on a 2007 pt cruiser non turbo, it cranks has fuel pressure( just installed brand new fuel pump) good blue spark but will not start does anyone have any ideas or has anyone had this experience before? Any opinions would be appreciated.
Old 30 Jun 2011, 05:24 am
Default Re: Need help
What is the mileage and does it turn over and won't catch or won't turn over at all.
Old 30 Jun 2011, 07:09 am
Timing belt?
Old 30 Jun 2011, 07:24 am
Car has about 50 k on it, turns over very nice doesn't sound like it has any weak spots in it while turning over, don't hear anything abnormal when trying to start it,... :/
Old 30 Jun 2011, 07:25 am
Originally Posted by XtrmDC2 View Post
Timing belt?
That's why I was asking about the mileage but it is a 2007. Not saying he/she couldn't have put a lot of miles on in 4 years.
Old 30 Jun 2011, 07:48 am
It's awfully low fuel mileage for a new fuel pump as most PT's never need to change it and since you just put it in, I'd check pump fuse and fuel pressure since you already checked spark.
Fuse is #13 in the PDC (Power Distribution Center) under the hood.
Old 30 Jun 2011, 09:31 am
Good call, I know I have 40 psi at the pump ( old one only had 29) but not sure how much at the rail, I will have to double check that, btw any idea how much psi a pt should have? 40 still seems a wee bit low to me
Old 30 Jun 2011, 10:17 am
Update...just checked pressure going to the rail and it is 0psi
Old 30 Jun 2011, 10:18 am
According to Haynes, 53 to 63 psi
You answered before I did. Sounds like you found your problem.
Old 30 Jun 2011, 10:25 am
cruserdad1976's Avatar
sounds like a blockage and mine was running a solid 60 at the rail i thought that was to much
