Dash Gauges/Needles Stop Working
Old 01 Jul 2011, 06:32 am
Default Dash Gauges/Needles Stop Working
I have a 2002 Touring Edition. Is there any reason why the gauges in my dash would quit working but only when the car heats up from the outside temperature not the motor (above approximitely 80 degrees). When the outside temp cools down the gauges will work again but only once I pull the fuse and basically jolt or spark it where it plugs in (kinda like jump starting it). Not sure it might mean a relay or something is sticking from the heat. It works fine after I get it to work when it is cooler but gone when the day heats up. Any help would be appreciated. Hope this made sense because it is a kind of strange problem.
Old 01 Jul 2011, 07:26 am
Default Re: Dash Gauges/Needles Stop Working
Yes that is strange and it sounds like the old circuit board problem of a "cold solder joint" If the joint in a circuit board was broke or hardly making contact, heat or cold would affect if the circuit made contact probably by expansion and contraction. Might be something inside the gauge panel but I couldn't say what. Might be just a bad grounding problem. Here's a HOW TO link from our Tech section that tells how to take the dash apart to get to the instrument panel if you want to try and take it out. Sometimes taking something apart and putting it back together fixes it.
PT Dash Lamp Replacement
Old 01 Jul 2011, 08:13 am
Thanks for the advice. I knew it was strange problem. I thought about the solder joints but was hoping that it might be something that didn't require an easter egg hunt.
Gauges, A/C and Power Locks Stopped Working khorak Tech & Performance Forum 3 12 Jul 2010 09:43 am
Wipers Stop Working GAPT General PT Cruiser Discussions 19 20 Mar 2010 09:46 pm
KEYLESS ENTRY stop working partyd Sound and Security Forum 7 08 Jan 2010 09:11 pm
2006; Dash lights come on and needles go down irish_jedi Tech & Performance Forum 2 10 Sep 2007 10:29 pm
my OEM remote stop working like before??? Ctown Sound and Security Forum 4 30 Jul 2006 01:14 am
