1684 code - how long til it clears itself?
Old 03 Jul 2011, 11:37 am
Default 1684 code - how long til it clears itself?
How long does it take the 1684 code to clear itself?
I need to have my car inspected (NY State) and they won't pass it if they think I pulled the neg battery cable to clear fault codes.
2001 PT Cruiser, Base Model, Dark Blue
NGK GP-Series Platinum Plugs, Autolite Wires
116k, Avg. 22+mpg mixed driving
Old 03 Jul 2011, 12:27 pm
Default Re: 1684 code - how long til it clears itself?
Just clear it your self and try to pass it...that's what I would do. How can they know if is no code? I get that code all the time because I always disconnect then battery when I'm working on my car... which is very often
Old 03 Jul 2011, 01:01 pm
How to you clear the p1684 code? I don't have a DRB scan tool. Just a reader.
Old 03 Jul 2011, 01:15 pm
You can try unplugging the battery for a few minutes....mine doesn't show after that BTW do you get a check engine light?
Old 03 Jul 2011, 01:18 pm
No, no light. I just changed the p/s pressure sensor cause I was getting the 0551 code. Now that's gone but I have the 1684 cause I disconnected the battery. That's what makes it go on, right? Cause the battery was disconnected within last 50 starts? Do I have to start the car 50 times go get it to go away, or is there a certain amount of mileage and it will go out?
Old 03 Jul 2011, 01:20 pm
rcktpwrd's Avatar
Just drive the car for a few days before getting it inspected. As long as there are no other fault codes you won't have any issues passing.
Joel
www.rcktpwrd.com
Old 03 Jul 2011, 03:58 pm
As XtrmDC2 already posted; take off the negative battery cable for about 5 minutes. That will reset the computer and clear all stored codes.
Old 03 Jul 2011, 05:55 pm
rcktpwrd's Avatar
except the code he has is for a disconnected battery... Only solution is to drive the car for a few days to be sure the computer registers all sensors are working properly, then get it inspected.
Joel
www.rcktpwrd.com
Old 03 Jul 2011, 07:11 pm
mdfrodolives's Avatar
How would they know you pulled the battery cable to clear the fault codes. Is it against the law to tinker with your battery cables in N.Y.?
If you're really worried, pull the battery cables, then clean the terminals. Then if they ask--before they pull your fingernails out--tell them you had a starting problem due to corroded battery cables.
Ah, to live in a place where the government is afraid of the people ....
Tim
Old 03 Jul 2011, 07:32 pm
SCBluePT's Avatar
I'm with mdfrodolives on this one.If the light is not on,how will they know the battery was disconnected?
Codes 1684 & 0123 - What did I do? EDGEFIND Tech & Performance Forum 11 18 Sep 2012 08:00 pm
ptc won't shift out of low 0700 1684 Manwell Tech & Performance Forum 4 11 Dec 2010 02:13 pm
Help needed for P 1684 code JazzeCouture General PT Cruiser Discussions 1 15 Nov 2008 02:07 am
P 1684 & P 0455 Codes Opiate General PT Cruiser Discussions 6 21 Sep 2004 07:03 pm
It's a long, long drive to Germany... Ed Lim Exterior Accessories Forum 0 05 Jun 2003 03:33 am
