Valve cover torque specs
Old 04 Jul 2011, 01:06 pm
Default Valve cover torque specs
I've spent some time here looking for the torque settings and tightening sequence but can't seem to find it. Does anyone have the torque setting and sequence for the valve cover on a 2004.
Thanks
Steve
Old 04 Jul 2011, 03:29 pm
Default Re: Valve cover torque specs
Snug, and then maybe a pinch more. Really, worrying about torque values on every single component bolted to your engine is unnecessary.
Use 1/4" drive, use one hand and most of all, use common sense. It'l be fine.
Old 04 Jul 2011, 04:25 pm
I never torque anything and never had a problem...
Old 04 Jul 2011, 08:01 pm
mdfrodolives's Avatar
I have a Hayne's Manual that's for 2001 through 2003. It says to tighten all the valeve cover bolts to 40 inch pounds, initially. Then--when all are at that setting, tighten all of them to 80 inch pounds. Then when all are that tight, do the final tightening to 105 inch pounds. Sounds like a weird way to do it, but I bet it won't leak if you follow these directions ....
Before doing this, apply a "light" coating of RTV sealant onto the corners of number 1 and number 6 camshaft bearing caps (I guess some oil will leak if this isn't done). In other words, the back corners as you're facing the engine from the front of the car.
Tightening sequence: Do all the middle ones first, starting with the bolt in the middle of the valve cover, then the one just above it, then the one just below it. Then do the same sequence for the left three bolts. Then do the same sequence for the right three bolts.
Then get a Hayne's manual, because it may not be perfect, but it shows a lot of torque settings and other stuff you will need in the future.
I don't wrench all that often anymore, so I use a torque wrench. My bad!
Tim
Old 04 Jul 2011, 08:07 pm
Thanks, just the info I was looking for.
Steve
Torque specs hidinginparadise General Turbo Discussions 1 19 May 2011 02:32 pm
Valve Cover Torque duffner Turbo Performance 19 13 May 2010 09:37 pm
torque specs gokart Tech & Performance Forum 2 15 Apr 2009 01:46 pm
torque specs? youngcruiser Tech & Performance Forum 8 21 Mar 2006 03:49 pm
Torque Specs irelandmoss Tech & Performance Forum 2 18 Jan 2006 09:07 am
