2005 PPT Cruiser Still Stumbles after lots of work done.
Old 07 Jul 2011, 06:51 am
Default 2005 PPT Cruiser Still Stumbles after lots of work done.
Hey All, I have been referencing this site me and my wife bought a brand new pt cruiser in 2005 when we had our first kid.
It has 100,000 miles on it right now had it serviced under warranty for awhile but after that did my own work mostly except timing belt /water pump.
Basically it has had a idle issue and stumbles. I cannot figure out how to cure it. sometimes its worse than other s which leads me to believe its a sensor going in and out into the main box maybe. I have tried other tips I have found on this site.
One issue did start back when I changed my own plugs/wires for preventive and it would not run right until I put MOPAR orginal new wires on and the recommended plugs.
* Camshaft position sensor changed
*CKP sensor Changed
*Timing belt/waterpump/rad fan/ Professionally changed
**air filter K&N Clean
*Plugs /MOPAR wires changed
I am assuming its a spark issue since it stumbles on accleration sometimes worse than others.
Any Ideas Everyone????
My 1973 beetle runs better than this thing has for 5 years!
Old 07 Jul 2011, 07:06 am
Default Re: 2005 PPT Cruiser Still Stumbles after lots of work done.
I just posted this for someone else. Try reading the information given in the article and see if it relates to your problem.
http://www.motor.com/magazine/pdfs/032008_02.pdf
Old 07 Jul 2011, 07:22 am
rcktpwrd's Avatar
Has the car always acted this way? If so I would start by closing up the gap in the spark plugs slightly.
Have you ever cleaned the throttle body? If not get some tb cleaner spray, pull the tb off and clean it out good.
Joel
www.rcktpwrd.com
Old 07 Jul 2011, 11:42 am
Thanks guy's That article is really good and the article is my symptoms to a "T" I will try all of throttle clean and suggestions and check the a/c fan speeds.
Old 07 Jul 2011, 01:19 pm
Is your CEL on? Even if it's not, it'd be worthwhile to check for active and stored codes. Most any auto parts store can perform that service for free.
Old 07 Jul 2011, 01:31 pm
...or just follow the instructions we have on the forum and get the codes yourself.
How to retrieve fault codes.
Old 07 Jul 2011, 04:38 pm
Is it stumbling only at idle and right off idle, or even while cruising/accelerating?
Old 12 Jul 2011, 05:31 pm
Had tons of advance auto cpu test done always saying " cylinder #3 misfire" or "cylinder # 1 misfire" Dealership used to just blow me off and say they reprogrammed my cpu.
Old 12 Jul 2011, 08:56 pm
I wonder if you have a intake manifold leak Just get a can of throttle body cleaner and spray it around the intake manifold gaskets with the engine running and see if the idle goes up... if it does, that gasket is leaking
01' PT stumbles, barely runs jarvisxl Tech & Performance Forum 2 23 Jun 2011 06:14 am
2005 non turbo engine work in a 2002? darkostoj General PT Cruiser Discussions 2 01 Oct 2009 08:30 pm
'02 Cruiser with lots of problems :( slpknt2886 Tech & Performance Forum 4 07 Aug 2007 02:17 pm
The PT Cruiser is a "work of art"... Gary04GT General PT Cruiser Discussions 4 20 Apr 2005 09:31 pm
convert into a work cruiser rexdean Exterior & Interior Styling 1 09 Oct 2003 01:01 pm
