Oil Light
Old 08 Jul 2011, 11:52 pm
Exclamation Oil Light
My Oil light came on so my husband did an oil change and put a new oil filter in but the the oil light still comes on. He even disconnected it and it still came on.
Anyone help?
Can i still drive the car?
Old 09 Jul 2011, 12:10 am
Dill's Avatar
Default Re: Oil Light
Im not by any means a mechanic but I do know usually oil light means fix me now! Lol..
But since you know ur all fresh I see no reason why you couldnt drive it, hut well see what others say.. How long did you disconnect the batt to clear to light?
Old 09 Jul 2011, 12:25 am
My husband didn't disconnect the battery he disconnected the oil light itself and it still came on after 20 secs and cause i've only had it about a month and am still waiting for the manual to come we have no idea what to check for
Old 09 Jul 2011, 12:30 am
I'd be concerned about low oil pressure. Low oil pressure can be caused by several different things from low oil level, clogged oil pickup tube, failing oil pump, failing engine bearings.
You really should have a mechanic put a actual oil pressure gauge on the engine to determine if the pressure is Ok. If it is, then maybe a new pressure sending unit is in order.
Of course, read your owners manual and see what it says about it. Maybe search around on the board here and see if there is a procedure for "clearing" a oil light.
Old 09 Jul 2011, 12:58 am
cruserdad1976's Avatar
id net its the sending unit not the easiest to get to but not to bad change it and see what happens id bet you are good to go
Old 09 Jul 2011, 01:12 am
Exclamation Re: Oil Light
The oil pressure is fine, the temp doesn't go up and there is no funny smell.
My husband pulled everything apart and it all seems fine, the light just won't go off!!
Old 09 Jul 2011, 08:04 am
rcktpwrd's Avatar
I agree with this, probably just a bad sending unit, it's a somewhat common issue...
Joel
www.rcktpwrd.com
Old 09 Jul 2011, 08:26 am
I agree also. It's the sensor.
Old 09 Jul 2011, 08:49 am
I have replaced the sending unit in my GT twice so far. Pep Boys has a "help" section that has a Chrysler sending unit deep socket that works great to remove, and install the oil pressure sending unit. I wouldn't try to use any other tool as you would probably break the new sending unit during installation.
Old 09 Jul 2011, 02:43 pm
mdfrodolives's Avatar
Did the oil light come on when you first start the car? At idle, I mean? Or did it stay on while driving?
And how did your husband disconnect the oil light? If he disconnected it at the oil sending unit--where Crewzin has supplied a diagram--then maybe the light will just continue to stay on because the oil sending unit wire is grounded. That's just a guess, because I've never heard of someone disconnecting the oil sending unit--and just leaving it like that.
Last week my wife reported that our PT oil light would come on when she first started the car--it was at idle, naturally. Then she turned off the engine and started it again--and no light came on. This happened a few times--but not always. Oil was full--and no funny smells.
I had the oil sender replaced for cheap (with someone who had a lift, because it's a bear to get to the unit with jackstands, only). I bought the oil sending unit at the dealer--no aftermarket electric items for me.
The problem is solved.
Tim
Showing ABS light, Brake light, Traction light on Dash fox50h Tech & Performance Forum 19 18 Feb 2014 11:40 pm
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
Mork's Tail Light and Reverse Light Tint Progress Morkeste Exterior Accessories Forum 30 23 Jun 2011 12:20 pm
tail light broken, but brake light works dirtydmix General PT Cruiser Discussions 8 09 Mar 2011 09:59 pm
car wont start. car alarm light and airbag light on trigimon Tech & Performance Forum 7 05 Nov 2010 03:42 pm
