Autotap
Old 01 Jan 2004, 11:07 pm
Send a message via AIM to Rolo
Default Autotap
Anyone use this on a PT?
http://www.autotap.com/
It looks to be a good way to establish a baseline and look for problems early.
Old 02 Jan 2004, 12:17 am
Get a real scanner.
If you want to get serious about the computer controls, you need a professional scan tool.
You can get a good deal from the e-bay sellers.
Look for OTC or MT-2500 (Snap-On). There are others, but those will get you going.
Old 02 Jan 2004, 12:28 am
If anyone is interested:
OTC
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2451857310
MT-2500
http://cgi.ebay.com/ws/eBayISAPI.dll...category=42291
MT-2500
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2451785069
2002 Inferno Red PT Limited
Mercedes Wiki
Old 04 Jan 2004, 02:39 am
Thanks for the replies!
I could not find the MT-2500 on Snap-on's site, only the MicroScan, and it seems pretty limited. The OTC looks even less. Is there anything that these scanners do that Autotap does not? (other than requiring a computer, but I like that since there are no logging/memory limitations)
Old 04 Jan 2004, 11:40 am
Send a message via AIM to Alicha
Autotap is good for one thing...scanning codes. It's worthless for any type of datalogging because the OBDII port is simply too slow to do real logging.
Old 04 Jan 2004, 11:55 am
A real scanner includes TSBs, circuit descriptions, possible causes, access to datastream, recording, airbag, ABS, body control, and TCM data along with engine stuff.
A consumer grade scanner will not read the diagnostic codes that the OEM radio will flag if a speaker shorts out.
How about bi-directional data?
A real scanner allows you to energize relays, advance spark timing, adjust idle speed, turn on cooling fans, .... heck, I can unlock the doors from the scanner.
For $2000, you will get a good scan tool.
Don't ask us,... ask the mechanics around your area.
I'll bet none of them use a PC or PDA based scanner.
Because of the Snap-On easy pay plan, I'll bet the majority of them use the MT-2500 red brick.
ODBII Scanners crazie.eddie Tech & Performance Forum 8 15 Oct 2004 09:56 pm
