2003 overheating when driving at low speed
Old 12 Jul 2011, 09:14 am
Default 2003 overheating when driving at low speed
My automatic 2003 PT Cruiser has started overheating whenever I drive at a low speed,it's fine when I'm driving on the highway going;after having a diagnostic test done at a shop I've had the thermostat&water pump changed,and the mechanic assured me this would stop the overheating..but no such luck My brother in law told me the fan in front of the motor would got stuck when he tried manually turning it,could this be what's wrong,and if not:what else could it be?
Old 12 Jul 2011, 09:38 am
Default Re: 2003 overheating when driving at low speed
Assuming your crankcase if full of oil, your coolant tank is topped off. I would say your fan is not coming on when needed.
An easy check is to start the car and let it idle. When it comes up to proper operating temperature observe the fan to ensure its coming on. If the fan doesn't start despite the temp continuing to rise -- your fan is not working properly leading to the overheat condition.
The fan is also supposed to kick on when you turn on the A/C. Does it operate then?
Old 12 Jul 2011, 06:45 pm
mdfrodolives's Avatar
You might need a flashlight and a mirror to see the fan blades, turning. But I suspect you won't see them turn. It sounds like your fan is kaput. My 2003 Limited Edition lost the fan at about 65,000 miles.
Does your engine stumble at idle when the A/C is turned on? And does it blow hot air out the vents at idle--but cold air when on the road?
Tim
Old 12 Jul 2011, 07:33 pm
yes,it blows hot air at first then graudually cold. I called a part place and they have a fan motor and a fan assembly,which one would I need
2003 pt cruiser overheating madcop811 Southeast PT Forum 33 06 Feb 2012 10:55 am
OVERHEATING 2003 on streets oldorange Tech & Performance Forum 4 04 Sep 2010 11:28 pm
2003 pt overheating yousai General PT Cruiser Discussions 5 08 Aug 2010 08:24 pm
01 Pt Overheating at high speed only blackcat317 Tech & Performance Forum 4 13 Apr 2010 09:30 am
Overheating Driving me nuts sandyltn12 Tech & Performance Forum 7 28 Mar 2010 11:08 pm
