Oil Pressure flucuations
Old 13 Jul 2011, 11:50 am
Default Oil Pressure flucuations
The oil warning light and buzzer are coming on intermittently at idle after the engine is at operating temperature. Engine (2.4) has 137K miles on it. Checking for fault codes shows none. I pulled the oil pressure sending unit and installed a mechanical oil pressure gauge. From a cold start the oil pressure was 84psi. Under moderate acceleration it peeked at 95 psi and then settled in to 50 to 60psi and 30 psi at idle with the engine at normal operating temperature. This seems pretty normal to me. I have purchased an OEM oil pressure sending unit and am going to install it today. I'm replacing the sending unit even though it's not throwing a fault code. I think it's probable that the sending unit could be bad w/o showing a fault code.
I'm just thinking out loud here and wondering if I have missed something before I install the new sending unit this afternoon.
Thanks
Steve
Old 13 Jul 2011, 02:24 pm
rcktpwrd's Avatar
Default Re: Oil Pressure flucuations
sounds like a bad sending unit.
Joel
www.rcktpwrd.com
Old 13 Jul 2011, 03:34 pm
I haven't had it happen to me....yet......but it is not uncommon for the sending unit to fail. Since you put in the mechanical gauge and your pressure is good, you are on the right track.
I don't think PT's have many issues with oil pressure. Pretty stout engines unless you overheat them. I am at 189K on mine and it runs great
pressure..... superpug666 Turbo Wheels/Suspension/Handling 11 23 Jun 2011 09:56 pm
Where is the A/C low pressure valve? yl003760 General PT Cruiser Discussions 1 29 Dec 2009 07:36 am
Oil Pressure 408v8 Tech & Performance Forum 4 23 Nov 2007 08:56 am
Pressure washer Mr.Barton The Detail Shop 7 27 Oct 2004 09:19 pm
Oil Pressure THier Tech & Performance Forum 2 28 Jun 2004 06:16 pm
