OBX UNDERDRIVE CRANK PULLEY 03-06 PT CRUISER 2.4L TURBO
Old 13 Jul 2011, 09:10 pm
ROCKETMAN8060's Avatar
Default OBX UNDERDRIVE CRANK PULLEY 03-06 PT CRUISER 2.4L TURBO
Is anybody has this pulley in their car? What do you think about it? Is a good idea have this item install?
OBX UNDERDRIVE CRANK PULLEY 03-06 PT CRUISER 2.4L TURBO | eBay
ROCKETMAN8060
Old 13 Jul 2011, 09:25 pm
Default Re: OBX UNDERDRIVE CRANK PULLEY 03-06 PT CRUISER 2.4L TURBO
Stay away from OBX!!!! They are: "el cheapo" stuff
Old 13 Jul 2011, 11:11 pm
tryingbe's Avatar
A/C will work poorly & alternator will work poorly.
Underdrive pulley is no good for a street car.
I'd know, I had one.
85 GLH
Watch out for anchor engine mounts!!
Old 14 Jul 2011, 03:15 pm
Thanks guys!!
ROCKETMAN8060
Old 15 Jul 2011, 07:08 pm
UptownSport's Avatar
Have that on the Neon.
It's an excellent piece; a direct copy of the Unorthodox Racing (UR) pulley.
My brother bought an actual UR, they're exactly the same.
Mine has PS / AC pulley parted, it weighs next to nothing.
And it has about 200,000 miles on it now
Old 15 Jul 2011, 07:10 pm
Please tell me more!
ROCKETMAN8060
Old 15 Jul 2011, 07:26 pm
Do you have that on a SRT4?
Old 15 Jul 2011, 07:31 pm
Heyyyyyyyy Che!!!! What uppppp!!!!!
ROCKETMAN8060
Old 15 Jul 2011, 07:34 pm
Ohhhh Look what I found!!!!!
PT Cruiser Unorthodox pulley. | eBay
Unorthodox Racing pulleys are "THE ORIGINAL", the first of their kind in the sport compact aftermarket and our most popular crank pulleys. These crank pulleys increase performance by reducing the engines spinning weight and also because they underdrive all the accessories (a/c, alternator, p/s & w/p). We are very careful not to overdue the amount of underdrive for two main reasons. First, it is important to keep the alternator, air conditioning, power steering, and water pumps moving fast enough for every day driving. Second, not much horsepower is gained from extreme underdriving. We always keep our underdrive percentage under 20% allowing us to maintain factory specified outputs for the accessories. This care in design allows you to upgrade your stereo to a system of up to 600 watts (RMS) and not have any charging problems. The underdriving is done at the crank pulley, not the accessory pulleys. We do this to maximize the weight loss at the crank where most of the horsepower gains are realized. The underdrive version gives you 10-15% more power than the stock diameter version. Any of our accessory pulleys can be used in any combination with our underdrive pulleys or purchased as a set. So when you want the best don’t settle go with "THE ORIGINAL". These pulleys are available only in polished finish.
ROCKETMAN8060
Old 15 Jul 2011, 07:38 pm
Heyyy WAZUUUUPPP!!!
Under drive Crank pulley for TURBO ROCKETMAN8060 Turbo Performance 3 18 Jan 2010 05:16 pm
underdrive pulley..? brightlight07 Tech & Performance Forum 3 26 Jun 2009 09:04 pm
UNDERDRIVE PULLEY? & PLASTIC INTAKE ptTurbo528 Turbo Performance 6 30 Nov 2005 07:57 pm
Underdrive pulley 1lowufo Tech & Performance Forum 3 31 Aug 2004 08:01 pm
Underdrive Pulley Seems To Make a Difference! FRM3 Turbo Performance 18 17 Nov 2003 11:33 pm
