2003 pt won't start
Old 14 Jul 2011, 08:26 am
Angry 2003 pt won't start
I replaced the coil, wires plugs and the crankshaft sensor. no go. THe codes I got were 129,118 and 522 in that order. 522 is oil pressure switch. Could the pressure switch cause the car not to start? can you bypass this switch to test that condition some how? Newer timing belt and was running just fine. The car started once and ran good but just quit again. Fuel pressure test was good over 100psi- 120psi.
I got spark and fuel. In my hay day that was the only thing required.
When I get this running its gone!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 14 Jul 2011, 08:57 am
Default Re: 2003 pt won't start
I hate to help you out just to get rid of it but yes the oil sensor will stop the car from starting. I've seen it happen a few times. I know of no way to test it.
P0129: Barometric Pressure Sensor Out -Of-Range .
P0118 ECT Sensor Voltage Too High.Engine coolant temperature sensor input above the maximum acceptable voltage.
2003 Touring doesn't start TimothyG Tech & Performance Forum 3 11 Jan 2011 07:36 am
2003 Pt Won't Start but has lights n sounds CATCH22 General PT Cruiser Discussions 5 10 Jan 2011 04:40 pm
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
2003 pt crusier wont start smith4384 General PT Cruiser Discussions 4 19 Jan 2009 02:27 pm
my 2003 pt makes a squilling noise on start up circe Tech & Performance Forum 8 09 Dec 2007 08:07 pm
