Codes po116 and po118
Old 17 Jul 2011, 05:52 pm
Default Codes po116 and po118
Just got the car all put back together. I just in a new Timing belt, Idler, Tensor, and Water pump. I have bleed out the system to the point I am getting no more air in the tube. The Fan comes on as soon as the car starts. It also appears the temp gauge isn't working. The engine isn't doesn't seem to be getting hot. I did disconnect the ECT during the work, so I would not have to worry about it getting crimped or broke during the work I did. But I also hooked it back up. The car starts, idles, and runs fine. Turn the key through the window and fires right up. I put about 5 to 7 miles on it and had it up to about 45. No missing nothing. I am going to try and get to the ECT in the mourning. I can't find any how to's on this.I am thinking about pulling the head light. Just no room with the AC lines. Can any body give me some idea's. Also I did unhook the battery 3 times during bleeding the radiator. It doesn't want to clear the codes?? Sorry that should be code p0016 and p0118
thanks
Codes? BladeRunner Tech & Performance Forum 4 12 Apr 2011 10:07 pm
TOO MANY CODES!!! Nonie Tech & Performance Forum 13 20 Mar 2011 12:21 am
Codes, Codes, everywhere there's Codes Neen Tech & Performance Forum 6 21 Nov 2008 07:59 pm
No Codes?? BB General PT Cruiser Discussions 2 13 Aug 2005 08:25 pm
obd codes camarillogolfer General Turbo Discussions 5 06 Aug 2004 11:10 am
