Engine will not start
Old 17 Jul 2011, 06:45 pm
Default Engine will not start
I just finished a timing belt and valve job on a 2007 2.4 L. Got everything back together. The car will not turn over, the ignition seems to be disabled. the security light is on when I turn the key and remains on as long as the key is in the start position. the battery was disconnected for about 3 weeks. Is there some security mode I don't know about? Any Ideas?
Old 17 Jul 2011, 06:48 pm
Default Re: Engine will not start
No security mode. Are you sure the battery is charged enough to turn over the engine?
Old 17 Jul 2011, 07:42 pm
That was my first thought but I had the battery load tested and it checked out OK. The reason I thought security is the security light stays on and blinks rapidly
Old 17 Jul 2011, 07:56 pm
Yes, it shouldn't blink like that but the owners manual doesn't saying anything about it. Only says it will blink rapidly when the alarm system is arming like when you hit the lock button on the fob. Maybe somethings wrong with you key fob?
Old 17 Jul 2011, 09:41 pm
Dill's Avatar
Have u had it a while? Sometimes theres a remote lockout that some dealers put in cars.
Old 15 Mar 2012, 08:41 pm
Have you used the correct key? Try the spare and see if the chip in the key may start the engine. If you have the security system it, for some reason may not recognize the first key you tried. Also the cam sensor on the side of the valve cover( left side) may be the cluprit. As it will allow the car to start if there is no signal relayed to the computer to fire it up.
Old 15 Mar 2012, 09:02 pm
Do you realize that the post you're replying to is almost a year old?
Jerry
engine won't start thinking it's a bad ECU luckybadazzboy Tech & Performance Forum 23 24 Mar 2011 12:12 am
Engine start button careyk General PT Cruiser Discussions 0 09 May 2010 01:15 pm
Engine start button careyk General PT Cruiser Discussions 13 26 Aug 2008 08:45 pm
PT Cruiser Engine Start Up skylight PT Cruiser Videos 0 28 May 2008 07:48 pm
engine start button Musicman Exterior & Interior Styling 6 31 Dec 2004 12:24 am
