error codes P0032 and P0038
Old 19 Jul 2011, 06:33 pm
Unhappy error codes P0032 and P0038
What needs to be done when you get these codes. i have 04 turbo with 109,000 miles
Old 19 Jul 2011, 07:24 pm
Default Re: error codes P0032 and P0038
It's saying both your oxygen sensors need changing. Which is kind of unusual for both of them to go bad at the same time. Did you happen to fill up your car with leaded gas the last time?
P0032 H02S Heated Oxygen Sensor Control - Circuit High (Bank 1 Sensor 1)
P0038 H02S Heated Oxygen Sensor Control - Circuit High (Bank 1 Sensor 2)
Old 20 Jul 2011, 05:48 am
no leaded gas. Would these sensors keep the car from starting? The engine light did come on for a short time but now it will turn over but wont start.
Old 20 Jul 2011, 06:12 am
No, they won't stop the engine from starting. You have other issues and not enough information. Check your battery and charging system. Check the computer for any fault codes.
no error codes lt4supr Tech & Performance Forum 4 14 Aug 2009 07:34 pm
Error codes mr.troy Tech & Performance Forum 3 16 Jan 2007 04:26 pm
ERROR CODES Kirby General PT Cruiser Discussions 4 24 Oct 2006 03:15 am
