Transmission problem
Old 19 Jul 2011, 09:23 pm
csd csd is offline
Default Transmission problem
I have the following, my pt won't shift, it's stuck, on 2nd, reverse works fine.
I changed the fluid and filter, didn't help, we hooked it up to a scanner, and said , needed new solenoid. Installed new solenoid, didn't help, but got much more soft and on certain ocations it worked. What i got are squares around, all gears on the instrument panel, speedo doesn't work my guess is the sensor, but it's only 6 months old, replaced it before, , took it out and tested with a multimeter , seems fine. Any ideas?
Here si what it looks like.
Old 20 Jul 2011, 01:22 am
ROCKETMAN8060's Avatar
Default Re: Transmission problem
I had a similar probem and it was the RANGE SENSOR SWITCH Part #4659676AC Im sure that is problably your problem!!!
Transmission Solenoid and Valve body - A604 RANGE SENSOR SWITCH (PRNDL)99up NEW OEM#4659676AC
I got it install at Chrysler because the tech told me is inside of the transmission! Then he reset the software on my transmission and now it runs great! Go see if it's that! Good luck!
ROCKETMAN8060
Need help with a transmission problem. pinny General PT Cruiser Discussions 3 03 Aug 2011 04:31 pm
transmission problem? if so what next? yvetteski General PT Cruiser Discussions 4 25 Feb 2009 01:42 am
Transmission problem perhaps? banddork123 General PT Cruiser Discussions 2 09 Oct 2008 09:05 pm
Transmission problem turbotime Tech & Performance Forum 3 13 Nov 2005 06:28 pm
transmission problem dbraveman General Turbo Discussions 12 09 Mar 2004 11:44 pm
