05 2.4l wont read speed
Old 20 Jul 2011, 11:29 am
Exclamation 05 2.4l wont read speed
Hello tho im new i need urgent help my PT cruiser will not mark the speed on my dash, i have changed the input and output speed sensors and still does not mark the speed its an automatic if that helps thank you guys for your time.
Old 20 Jul 2011, 11:54 am
Default Re: 05 2.4l wont read speed
From a Google search...
I own a 02 pt cruiser. The speedometer and tachnometer stopped working. What is causing this? How do I fix it? - Yahoo! Answers
Old 20 Jul 2011, 11:58 am
Thanks at this point anything will help
Old 20 Jul 2011, 12:16 pm
Did not work
Old 20 Jul 2011, 12:21 pm
Just for the heck of it. Do you know the trick of making all the dials do a "check"?
Put the key int the ignition and before turning it forward, push and hold the odometer reset button. Don't turn the engine on when you turn the key forward. What this does is make everything in all three gauges start to do a check of the system. It starts out by checking all the numbers in the middle dial ex: 1111111 then 2222222 etc. Then it goes to the gas gauge needle and makes it go 1/3 of the way up, then half way, then 2/3rds then all the way to past full, then it goes to each needle in all three gauges and tests them. Try that to see if your speed dial does the test.
You don't have to hold the reset button after the test starts.
Old 20 Jul 2011, 12:23 pm
Alright i will, i appreciate the help.
Old 20 Jul 2011, 12:30 pm
Only problem is, if it works, it only proves that the needle isn't broken. Doesn't really help with the problem your having.
Old 20 Jul 2011, 12:43 pm
Well all of the gauges and the odo worked but i took it for a test drive and still does not mark the speed, You've probably given me all your suggestions and for that i thank you but i will continue to find the problem, i am a ASE master certified technician believe it or not and i have never encountered this problem out of all the years ive been working.
Old 20 Jul 2011, 12:48 pm
Sorry it didn't help. ...when you say you changed the sensors, did you mean the one on the transaxle itself? The speedo works off the transmission.
http://www.allpar.com/forums/topic/1...-speed-sensor/
Old 20 Jul 2011, 12:49 pm
speedometer wont work after replacing speed sensor - Allpar Forums for Chrysler, Dodge, Jeep, Plymouth, and more
Its automatic.
Is the 4 Speed A/S realy a six speed? Ian-PT-GT General Turbo Discussions 11 16 Apr 2004 10:19 pm
Anybody with 20s?? READ 2 HELP chumper Wheels, Tires, Suspension 4 01 Apr 2004 12:00 am
PLEASE READ GTSteve General PT Cruiser Discussions 5 27 Oct 2003 03:55 am
another pdf to read. Punch Stage Turbo Kits 1 22 Oct 2003 08:01 pm
PLEASE READ! santa ana cruiser General PT Cruiser Discussions 2 04 Apr 2003 09:50 am
