PT Cruiser Forum (http://www.ptcruiserlinks.com/forum/)
-   Tech & Performance Forum (http://www.ptcruiserlinks.com/forum/tech-performance-forum/)
-   -   Why distilled water only? (http://www.ptcruiserlinks.com/forum/tech-performance-forum/37459-why-distilled-water-only.html)
falconut 21 Jul 2011 06:44 am
I hope this isn't a stupid question, but why can the HOAT coolant only be mixed with distilled water? I have an RO/DI setup in my basement that produces 0 TDS and I thought this was the best method to acheive pure H2O. Anybody know why RO/DI water can't be used? Is it too stripped?
XtrmDC2 21 Jul 2011 07:00 am
Re: Why distilled water only?
I don't know but distiller water is about $1 - $2 at CVS or Walgreen ;)
falconut 21 Jul 2011 07:40 am
Yeah, I know it's not expensive by any means, just curious if anybody knew.
The dealer has a premix gallon of red 5 year coolant for $14+/-, so I'll just get that. Hopefully they mixed it with distilled water. :laughing::laughing::laughing:
CREWZIN 21 Jul 2011 07:41 am
Mainly because they don't want you to use the crap that comes out of your home tap. The impurities, minerals and chemicals in tap water could possibly cause corrosion in the coolant which will deteriorate your cooling system over time.
www.TechGuys.ca | How to: Flush your radiator / cooling system
falconut 21 Jul 2011 07:45 am
I was just curious because they included deionized water in the do not use list in my manual. Maybe it was just DI was and RO/DI water is fine. But, I'll just go with the premix to be safe.
carolinagirl 21 Jul 2011 10:15 am
is this good antifreeze???
http://i56.tinypic.com/345c4sw.jpg
CREWZIN 21 Jul 2011 10:22 am
It IS MOPAR and somewhere it should have "Hybrid Organic Acid Technology (HOAT) written on it, which is what's recommended for the PT.
carolinagirl 21 Jul 2011 10:27 am
thanks...i wanted to make sure before I put it in my cruiser
falconut 21 Jul 2011 11:39 am
I just picked up the gallon of 50/50 delutted coolant, but I couldn't find HOAT on the label. It's number is MS-9769G, which from reading is supposed to be the right stuff. But, why make the manual say HOAT if the bottles are not going to say it.
RaineMan 21 Jul 2011 11:42 am
Distilled water goes in the radiator. Prevents minerals and other chemicals from building up in there over time.
Deionized water goes in the battery.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54
