![]() ![]() BTW.... 2001 PT Cruiser Limited, 5-speed standard with 105,000 miles. For the past couple months the car will fail to start at least once a day, or once every 10 starts or so. It makes no difference if the car has been running recently, or sitting overnight, or being in a garage or outside... there seems to be no common denominator for the times the car won't start. When I say it won't start, what I mean is this... the starter will make a couple pathetic 'hiccups' or 'turns' and then stop. I have to try over and over. Usually after 5 to 10 attempts it will start. Sometimes (like at night when the headlights are on) it will eventually wear the battery down and I have to push-start it (the car is a standard). In the past month I have replaced the battery and installed a brand new starter (it acts the exact same as the old starter, so that might have been a waste of money). The auto repair place ran about 8 hours worth of tests on it with no results... they couldn't even get the car to NOT start (it worked fine every time they started it). They have tested the battery and starter and both are fine. It still is giving me problems and I don't want to bring the car back to the shop without some sort of suggestions on what they should check. I went out of town for 5 days, came back, and it started right up. 1 hour later it would not start at the gas station. Any ideas on this? |
Symptoms like that usually point to the starter but you've changed it. Other times the actual cables start to build up corrosion and don't make a good contact on either the battery post or the starter itself.
Have you have the charging system checked including the alternator? |
Maybe the clutch interlock/safety switch is going bad?
Joel ![]() 2001 PT Cruiser 5-speed; 1976 Oldsmobile Cutlass S; 1990 Chevy 454SS; 1995 Caprice Classic woody www.rcktpwrd.com |
Thanks for the ideas. I am pretty sure the alternator is in good shape... no issues at all while driving the car (no dimming lights, battery stays charged, etc).
I will say this, though... I have gone through 4 batteries in the past 6 years. I don't usually pay anything since they come with a 24-month guarantee, but I find it odd that my car seems to kill batteries. Why would that be happening? However, despite the battery-killing characteristics, the car still ran great over the years... no starter problems. |
Well, you only THINK the alternator is in good shape but going through that many batteries, something has to be wrong. Lot of auto stores will check out the charging system for free. Most of us have a battery for 4 or 5 + years.
![]() Quote:
![]() You can check the cables for excessive resistance and visually inspect all the cables ends (battery, starter, alternator, and main chassis ground). If they are corroded or look burned, they should be replaced. It's often amazing what healthy battery cables can do for a car. |
Thread Tools | |
Display Modes | |
2001 PT dies and won't start | gto65racer | Tech & Performance Forum | 4 | 12 Feb 2011 12:36 pm |
2001 PT cranks but won't start | PT2001 | General PT Cruiser Discussions | 8 | 23 Oct 2010 10:41 am |
Hot start issue with 2001 | Rlundstrom | General PT Cruiser Discussions | 1 | 11 Oct 2010 02:52 pm |
New Cruiser(2001) and don't know where to start | ownlife | Tech & Performance Forum | 22 | 15 Apr 2009 07:22 pm |
My 2001 PT won't start! | envision_man | Tech & Performance Forum | 4 | 29 Jun 2004 08:30 am |
