A/C diagram for 2001 PT Cruiser
Old 22 Jul 2011, 07:08 pm
Default A/C diagram for 2001 PT Cruiser
Hello everyone
I am new to the site and am looking for a A/C diagram for a 2001 Cruiser as I am having A/C issues. My A/C is cycling on and off and only blowing hot air and I believe it to be the Low Pressure Switch. Any got a diagram or a picture of it so I know where I am looking. Thanks!
Old 22 Jul 2011, 07:23 pm
Default Re: A/C diagram for 2001 PT Cruiser
The LPS is on top of the Accumulator. East to take off, you won't loose any Freon but there's tiny "O" ring on the bottom, be careful or it will split when you put the new switch in.
After all that ...you don't need a new switch. The compressor wouldn't be cycling if the switch was bad but you can put a new one if you like. It's cheap and easy.
Old 22 Jul 2011, 09:01 pm
That's not the problem? You got an idea what the problem is then? I'd really like to try and get this fixed. Thanks
Old 22 Jul 2011, 09:10 pm
Well, a couple things could cause warm air. Not the right hi and low pressure or not enough freon to get the system up to pressure. If the compressor is cycling every few seconds, that's a sure sign of low pressure caused by low freon.
Another thing could be a blockage somewhere in the system. But I'd try getting the system up to pressure and the right pressure on both sides. That's the easiest thing to do.
Old 01 Aug 2011, 05:01 pm
Bought a recharge kit with gaugeand it shows that low is really high like in the 70's. Decided to take it to local sears and they verified this. The totattly bled the system and did a full recharge with die and also oil for right around $125.00 which incudes a 6 mo. warranty. Not bad. Thanks for the redirection
Old 02 Aug 2011, 10:44 am
Let us know if you lose the charge over time. Mine works fine after evac & charge, but blows warm again in 3-4 days. One shop says a leak in the liquid line ($400), another shop says total rebuild of system ($1800). Hard to trust anyone now days...
Old 06 Aug 2011, 02:34 pm
Running fine so far and don't see any signs of blood (aka: dye) leakage yet! If it stops working by winter I'll post back.
2001 pt cruiser stereo wiring diagram Koolaid2012 Sound and Security Forum 2 30 Sep 2015 02:38 pm
looking for a vac diagram for turbo pt cruiser 03 Dillinger10 Tech & Performance Forum 0 03 Jun 2011 10:35 pm
2001 fuse box diagram melissasusanne Tech & Performance Forum 3 28 Oct 2010 03:17 pm
A/C diagram windsblow General Turbo Discussions 3 19 Jun 2010 03:30 pm
Need Diagram KingKole02 Tech & Performance Forum 5 24 Jan 2006 09:09 am
